godblessfq wrote:
Maybe the shape2Dview in the draft workbench should use the view direction as the default projection direction.
Sound intuitive +1
+1 from me too. I thought there was already a ticket for this in the tracker but I haven't looked through Mantis in quite a while, and I could be wrong. If I find it I'll post a link, and if not I'll put in a ticket.
bejant wrote:+1 from me too. I thought there was already a ticket for this in the tracker but I haven't looked through Mantis in quite a while, and I could be wrong. If I find it I'll post a link, and if not I'll put in a ticket.
Edit: Feature requested as issue #2367.
Done with git commit 472e6b7. The projected object is sometimes rotated, though, but that is done by OCC, and t's not consistent (sometimes not, sometimes 90°, sometimes 270°), I don't know how to solve that...
yorik wrote:The projected object is sometimes rotated, though, but that is done by OCC, and t's not consistent (sometimes not, sometimes 90°, sometimes 270°), I don't know how to solve that...
Yes, hours lost in testing that feature.
As I work mainly on animation my idea is to scan the behavior of the tool and use ML to generate a supporting interface.
My problem still is how to bring such data back to FreeCAD
microelly2 wrote:es, hours lost in testing that feature.
I put this code into FreeCAD. The Draft-Workbench has now the same projection direction as OCC. This helps to project Draft-Dimensions to Part-Workbench-Shape-Projection in the Drawing Workbench.
I analysed the Projection behavior but unfortunately missed to save the results. I agree that the orientation of the projection is for human purposes unpredictable. My goal was to bring Draft-Projections and Drawing-Projections in sync. Otherwise, you have every time to rotate one or the other in a different way.
At least how to predict the projection direction is in the Draft-code. see: def alignToPointAndAxis_SVG in src/Mod/Draft/WorkingPlane.py
The rotation of the view depends only on the relative size of the direction-axis components against each other.
I would like to see a transformation tool like clone, instead adding a copy at the same level of the original object, it leaves it in a sublevel. This would allow to add second rotations (useful if you don't want to deal with (0.12345 , 0.7636 , 0.4578) rotations) or a scale operation.
This is how clone works:
|-Object
|-Clone
I mean something like this:
|-Transformation tool.
. . . |-Object
The operation tree will be less cluttered.
__________
Also, It would be nice to allow 0×1×1 on matrix. I mean, allow to "remove" the object without deleting it.
Its interesting if you have a parametric object like this (based on expressions):
[0o0o0]
And you want to have this:
[0o0o0o0o0]
Or this:
[0]
In the last case, the "o" is not present and matrix operation doesn't allow 0 copies of a object.
Estudié ingeniería técnica industrial en España y sólo me ha servido para estar en el paro, no me contratan porque no tengo experiencia, y no tengo experiencia porque no me contratan. No debí estudiar esa carrera.
Joyas wrote:I would like to see a transformation tool like clone, instead adding a copy at the same level of the original object, it leaves it in a sublevel. This would allow to add second rotations (useful if you don't want to deal with (0.12345 , 0.7636 , 0.4578) rotations) or a scale operation.
|-Object
|-Clone
. . . |-Object
A small additional request. Can we have the objects used to make a loft and sweep automatically hide after the new object is created? I do this manually all the time and it's kinda redundant. Thanks.
