Collection of differences between original master version and realthunder
F_Rosa
Re: Collection of differences between original master version and realthunder
Post by F_Rosa »
Yes, but why not?
Isn't this just another feature that can be brought over from the Realthunder branch into the FC version? :roll:
the focus is to merge the toponaming stuff now, the rest mostly depends on realthunder making the appropriate PRs for them or some interested party to extract the meaningful changes and make a PR (with everything that implies)
F_Rosa
Post by F_Rosa »
Thank you for the answer. Meanwhile, we will keep dreaming these PRs hapen soon... :)
adrianinsaval wrote: Thu Mar 30, 2023 3:35 am ...
Agreed, but how much tha actual LS3 branch is diverging from FreeCAD master?
Today a check in:
https://github.com/realthunder/FreeCAD
Is showing:
This branch is 5413 commits ahead, 6411 commits behind FreeCAD:master.
Plus a little note that seems not to be always explained, is that "RT branch" is not 100% compatible with "stock FreeCAD" files, it is said somewhere, but not in "clear view".
I suspect that most of the bugs and misbehaviour reported could be due to the fact that a file is made or modified by "RT branch" and then used with "stock FC".
From what I know from old post RT is not assuring that his produced files are 100% compatible with "Stock FreeCAD" once modified with his version.
Someone has more recent news about that ?
bambuko
Post by bambuko »
onekk wrote: Sat Apr 01, 2023 9:57 am ...From what I know from old post RT is not assuring that his produced files are 100% compatible with "Stock FreeCAD" once modified with his version.
I use RT branch almost exclusively (and Master branch only for educational/forum purposes).
I very seldom have any problems opening (master created) files in RT branch,
on the other hand - opening (RT created) file on master branch is usually causing problems.
In my (humble) opinion things got to a stage where the two are diverging so far that that any talk of merging things,
(especially since realthunder is one man operation) is futile.
I am just a lowly user, (talker on the forum) not "doer", so this is just an opinion
(after all, everybody has them on interweb :mrgreen: :lol: )
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
thomas-neemann
Post by thomas-neemann »
sketcher realthunder
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 2023.508.0.14555 (Git shallow) AppImage
Branch: HEAD
Hash: 8af53bfe8e1bdbeafcd2515160e96ea680fb8ef2
Python 3.11.3, Qt 5.15.8, Coin 4.0.1, Vtk 9.2.5, OCC 7.7.1
  * Curves 0.6.8
  * dodo 1.0.0
edit
What's the purpose of the swap?
thomas-neemann
chrisb wrote: Wed May 10, 2023 9:54 pm What's the purpose of the swap?
I assume that you can use this to solve part of the tnp if ids have changed in order to get an assignment that works again
thomas-neemann
in realthunder you can change the hotkeys for your view
OS: Ubuntu 22.10 (XFCE/xubuntu)
Version: 2023.521.0.14555 (Git shallow) AppImage
Branch: HEAD
Hash: f428979aa87456d1ce57e2ea78ee9d70dc7595e4
thomas-neemann
due to current events: in realthunder, separate solids are possible in part design per body
master
OS: Ubuntu 20.04.6 LTS (XFCE/xubuntu)
Version: 0.21.0.33458 (Git) AppImage
Hash: 8b89dd29d2382c72d738c52e8974216130ffa9db
Python 3.10.12, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
realthunder
Branch: HEAD
