is it possible to use local variables in Formula editor ?
Marc Bassini
Post by Marc Bassini »
Hello.
I need to compute an expression in the Formula editor which is pretty long and to use the result in the same expression.
To avoid to enter twice the epxression I would like to use a local variable.
As I don't know much of python in FreeCAD (and generally) I'm unsure it can ben done in Formula editor
Something like :
result = (a very long expression that I dont want to enter twice), (result > somevalue? somefunc(result): anotherfunc(result))
OS: Windows 10 build 19045
Version: 2024.113.0.14555 (Git shallow)
Branch: HEAD
Hash: 4235ee9c92d9822b434ec2bc8da7cee729fd9f3b
Python 3.11.7, Qt 5.15.6, Coin 4.0.1, Vtk 9.2.5, OCC 7.7.2
Locale: French/France (fr_FR)
Re: is it possible to use local variables in Formula editor ?
In Python it's possible, in Expressions not.
Marc Bassini
in an expression, is it possible to rewrite my above example so that result is computed only once without local variables ?
The Expressions page tells you what's possible.
Syres
Post by Syres »
@Marc Bassini Expressions can be let's say, simple Python, this took me a full morning to perfect with plenty of syntax errors and incorrect information being passed between the various conditions:
App.ActiveDocument.SectionView.setExpression('Scale', App.ActiveDocument.ProjGroup.ExpressionEngine[int(''.join( repr(e) for e in [idx for idx, (i,j) in enumerate(App.ActiveDocument.ProjGroup.ExpressionEngine) if i == 'Scale']))][1])
Not sure if it helps in the slightest but my method for looking up in stackoverflow.com was to use the search phrase python one liner followed by for example for loop or if else
With all due respect @chrisb that page was of no help for me when I was creating this little monster of an expression. If I can think of an easy way to break down how I built it approx two months ago I'll have a go but it'll be later this month.
