True.
Reopening the file, the L1+L2 dimension is just 24 but no more an expression.
It's not easy then to remodify it (need to suppress it then leave the sketch then ...).
Saving and reopening the file : same problem.
In the section on creating Pocket001, we are directed to change the Refine property to True. It was not obvious to me as a new user where to find the Refine property. Could we add something like "under Combo View, click Model, then look under Part Design to access the Refine property".
Hello! And thank you for a fantastic tutorial. I'm completely new to the CAD world, but am able to follow along so far.
One small thing that tripped me up is this statement:
"Select the point P2 and the Y axis and apply a Point onto object constraint."
If I follow that exactly, I apply the constraint with the horizontal axis on my screen, because that is the model's Y axis. However this is not what is meant (as can be seen by (a) looking at the sketch you provided and (b) immediately running into a problem.
What I'm trying to point out is the moment of confusion that results from that small difference.
It's a small thing.
I really appreciate the tutorial!
[EDIT] The list of constraints is also missing one point-on-object constraint: P4 should also be constrained to be on the horizontal axis on the screen, otherwise it can move in an arc. The constraint is shown on MP2, but doesn't appear in the text.
discobeez wrote: ↑Tue Nov 14, 2023 7:17 pm
I understand the confusion. It needs to be clarified that the axis referred to belongs to the sketch.
The list of constraints is correct, but the image is not. I'll update it.
