First build on Ubuntu - getting dependencies
NewJoker
Post by NewJoker »
after failing to compile FreeCAD from source on Windows (viewtopic.php?t=73143) I'm trying to do it using a virtual Ubuntu machine since the procedure seems to be easier there.
First, I followed this instruction: Installing on Linux and used the command below to install FreeCAD:
sudo apt-get install freecad
Unfortunately, it installed the 0.19 version. So I downloaded AppImage from weekly builds and used this instruction: https://wiki.freecad.org/AppImage#Unpacking_AppImages
Those commands allowed me to unpack the AppImage and start FreeCAD 0.22:
./FreeCAD_weekly-builds-34291-2023-09-14-conda-Linux-x86_64-py310.AppImage --appimage-extract
cd squashfs-root/
./AppRun
Then I went one step further and tried following the guide for compilation on Linux. According to it, a single command should be sufficient to install the dependencies on Ubuntu (https://wiki.freecad.org/Compile_on_Lin ... pendencies):
sudo apt build-dep freecad
But when I use it, I get this:
Reading package lists... Done
E: You must put some 'deb-src' URIs in your sources.list
What am I supposed to do now ? The guide doesn't explain this (at least not directly).
grandcross
Re: First build on Ubuntu - getting dependencies
Post by grandcross »
NewJoker wrote: Fri Sep 15, 2023 7:58 pm
By default, Ubuntu doesn't load software sources. Most people don't need it.
To load them you'll need to edit the packages available to your system. This is in the file `/etc/apt/sources.list'. I use vim, but you can use whatever editor you choose. You'll have to edit as root (`$ sudo vim /etc/apt/sources.list`)
For every standard repository, there is a corresponding source repository. For example,
deb http://ca.archive.ubuntu.com/ubuntu jammy main restricted
# deb-src http://ca.archive.ubuntu.com/ubuntu jammy main restricted
Remove the comment '#' from in front of the deb-src to enable. After saving the file, you'll have to update the package lists
$ sudo apt update
You should be then able to proceed with your install.
NewJoker
Post by NewJoker »
@grandcross Thank you for the explanation. I removed '#' from before deb-src http://pl.archive.ubuntu.com/ubuntu jammy main restricted and used sudo apt update but when I type sudo apt build-dep freecad, I still get:
Am I missing something here ? Should I remove '#' also from before jammy-updates main restricted, jammy universe and jammy-updates universe ?
grandcross
I would. Do the same for all the repositories in the file. Basically if you're using the 'deb', include the 'deb-src'.
NewJoker
Post by NewJoker »
@grandcross I uncommented all the "deb-src" lines, updated and the sudo apt build-dep freecad command finally worked.
However, when I downloaded the source code for compilation and, following the instructions for the out-of-source build (https://wiki.freecad.org/Compile_on_Lin ... le_FreeCAD), typed:
cmake ../freecad-source
I got this error:
CMake Error at /usr/lib/x86_64-linux-gnu/cmake/Qt5/Qt5Config.cmake:28 (find_package):
  Could not find a package configuration file provided by
  "Qt5WebEngineWidgets" with any of the following names:
    Qt5WebEngineWidgetsConfig.cmake
    qt5webenginewidgets-config.cmake
  Add the installation prefix of "Qt5WebEngineWidgets" to CMAKE_PREFIX_PATH
  or set "Qt5WebEngineWidgets_DIR" to a directory containing one of the above
  files.  If "Qt5WebEngineWidgets" provides a separate development package or
  SDK, be sure it has been installed.
Call Stack (most recent call first):
  cMake/FreeCAD_Helpers/SetupQt.cmake:31 (find_package)
  CMakeLists.txt:79 (include)
Exactly what should I do now ? On Windows, I was using CMake GUI and setting the directories for such variables as CMAKE_INSTALL_PREFIX there.
grandcross
My advice is to install the dependencies manually, which is what I normally do.
Directions are at https://wiki.freecad.org/Compile_on_Linux
Scroll down a little and expand the section on "Debian and Ubuntu". There are two methods described there with the first being what you've tried, i.e. getting the dependencies from the sources. The second is to install them manually. If you scroll down a little more you'll find this one liner:
sudo apt install cmake cmake-gui libboost-date-time-dev libboost-dev libboost-filesystem-dev libboost-graph-dev libboost-iostreams-dev libboost-program-options-dev libboost-python-dev libboost-regex-dev libboost-serialization-dev libboost-thread-dev libcoin-dev libeigen3-dev libgts-bin libgts-dev libkdtree++-dev libmedc-dev libocct-data-exchange-dev libocct-ocaf-dev libocct-visualization-dev libopencv-dev libproj-dev libpyside2-dev libqt5opengl5-dev libqt5svg5-dev qtwebengine5-dev libqt5x11extras5-dev libqt5xmlpatterns5-dev libshiboken2-dev libspnav-dev libvtk7-dev libx11-dev libxerces-c-dev libzipios++-dev occt-draw pyside2-tools python3-dev python3-matplotlib python3-packaging python3-pivy python3-ply python3-pyside2.qtcore python3-pyside2.qtgui python3-pyside2.qtsvg python3-pyside2.qtwidgets python3-pyside2.qtnetwork python3-pyside2.qtwebengine python3-pyside2.qtwebenginecore python3-pyside2.qtwebenginewidgets python3-pyside2.qtwebchannel python3-markdown python3-git python3-pyside2uic qtbase5-dev qttools5-dev swig
There is a high probability this will complain about `python3-pyside2uic` in which case remove it. You'll also need to install the following two packages:
sudo apt install pyqt5-dev-tools libyaml-cpp-dev
The first is mentioned in the documentation while the second is a new dependency added for the materials code.
NewJoker
Post by NewJoker »
grandcross wrote: Tue Sep 19, 2023 6:46 pm If you scroll down a little more you'll find this one liner:
Wow, quite a lot of dependencies. I used those two commands, the first one complained about this:
The following packages have unmet dependencies:
 python3-vtk9 : Breaks: python3-vtk7 but 7.1.1+dfsg2-10.1build1 is to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I checked and CMake is still throwing this error regarding Qt5WebEngineWidgets.
grandcross
Unfortunately installing dependencies from sources seems to have created some conflicts with older versions. I'd try removing the problem child.
sudo apt remove python3-vtk7
Unfortunately this may create some other errors for other dependencies. If it does, try removing them too.
Your cmake won't work until the conflicting dependencies are removed and the new ones installed, so don't worry about that. It helps to do the cmake in an empty folder so no old conflicts remain, so delete anything in your build folder first.
NewJoker
Post by NewJoker »
grandcross wrote: Tue Sep 19, 2023 7:03 pm I'd try removing the problem child.
Strange, this resulted in:
Package 'python3-vtk7' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 35 not upgraded.
So I've got no idea what to do about this. Should I remove python-vtk9 as well ?
grandcross
Looking back at the messages, the conflict looks the other way around. Try replacing the 7 with a 9? The 7 version is called for in the dependencies, but the conflict seems with the newer version. You're starting to venture into the trial and error phase :D
