Change parent but keep position.
koirat
Post by koirat »
How can I change parent of a body or a part but keep global location during change.
openBrain
Re: Change parent but keep position.
Post by openBrain »
What is parent ?
koirat
Post by koirat »
It is a parent element of a body in hierarchy.
When I drag body on top of a part, the part becomes parent of a body.
openBrain
Post by openBrain »
So it's an Std_Part object.
AFAIK you have to use Python console.
Let's say that you have an object 'OBJECT' and you want to drag it into a container 'PART' :
## Run the 2 below lines before mowing object
pl_orig = App.ActiveDocument.OBJECT.getGlobalPlacement()
pl_part = App.ActiveDocument.PART.getGlobalPlacement()
## Now drag OBJECT into Part before running following lines
App.ActiveDocument.OBJECT.Placement = pl_part.inverse().multiply(pl_orig)
koirat
Post by koirat »
openBrain wrote: Wed Oct 13, 2021 3:20 pm So it's an Std_Part object.
Thank you. This is quite convoluted but at least I have learned how to use python console.
Also I have made this one liner one can use when the body is in global space and you just dragged it into new parent.
(tested only few times so far)
App.ActiveDocument.BODY.Placement=App.ActiveDocument.PART.getGlobalPlacement().inverse() * App.ActiveDocument.BODY.Placement
openBrain
Post by openBrain »
koirat wrote: Wed Oct 13, 2021 11:15 pm Also I have made this one liner one can use when the body is in global space and you just dragged it into new parent.
Be careful to run this line only once, and indeed in the only simple case that you mention :)
plbarrio
Post by plbarrio »
I was looking for this featura and ended creating my own macro use it like in blender. Last node will the the future parent
__Title__    = "Reparent"
__Author__   = "PedroBarrio"
__Version__  = "00.01"
__Date__     = "2023.6.7"
debug = False
'''Usage:
This macro Changes parent maintaning Global coordinates.
Last Object Selected should be the parent.
If the shape is a BaseFeature inside a body, the base feature's placement in the body is adjusted.
def printObjectInfo(obj):
    print(f'ObjectName is {obj.Name}')
    print(f'ObjectLabel is {obj.Label}')
    print(f'Placement is {obj.Placement}')
    print(f'GlobalPlacement is {obj.getGlobalPlacement()}')
    for par in obj.InList:
        print(f'Parent is {par.Name} with Label {par.Label}')
        for prop in par.PropertiesList:
            print(f'   {prop} = {getattr(par,prop)}')
            if getattr(par,prop) == obj:
                print( "Changed property '"+prop+"' of object "+par.Label+" from "+obj.Label+" to ")
## Objetos seleccionados
selt = Gui.Selection.getSelection()
## Comprobaciones
if len(selt) < 2:
    print('Select More than 1 objects, the last one should be the new parent')
    shift = App.Vector(0, 0, 0)  # bail and do nothing
else:
    ## Target es el último elemento
    tar = selt[-1]
    print('\n Target Object')
    printObjectInfo(tar)
    ## Comprobamos que el destino sea de tipo part
    if (tar.isDerivedFrom("App::Part") == False):
        print('Target object is not of type Part')
    else:
        App.ActiveDocument.openTransaction('Undo Reparent Mantain Coordinates ')
        for obj in selt:
            if (obj  != tar):
                print('\n Moving Object')
                ## Cambiar localizacion
                obj.Placement= tar.getGlobalPlacement().inverse().multiply( obj.getGlobalPlacement() )
                ## Cambiar de padre
                ## Quitar del padre original
                    if (par.isDerivedFrom("App::Part")):
                        par.removeObject(obj)
                ## Poner en el padre nuevo
                tar.addObject(obj)
        App.ActiveDocument.commitTransaction()
        App.ActiveDocument.recompute()
