I misused the quoting feature to draw your attention once more to the slightly off-topic matter of finding unused values in the spreadsheets...
Sorry for that.
Now it can be done using the mention tag e.g. like this:Ulicad wrote: Ping
[mention]Ulicad[/mention]
Thank you so much! All of the given information truly is helpful or even comforting !chrisb wrote: ↑Fri Jun 02, 2023 4:47 pm To draw someones attention we had formerly to quote users with a "ping" like this, where you remove the post_id:Now it can be done using the mention tag e.g. like this:Ulicad wrote: PingWhich gives you a notification, e.g. for a sentence like: @Ulicad is far more chaotic than FreeCAD.Code: Select all
@Ulicad
Sorry I don't know graphviz, and neither how it is working, but each objects has some properties so probably it is a matter to know how to extract informations from objects.
Could scripting be a work around for this case?
Hello Carlo, thanks for your help!
Oh my dear - these works definitely needed quite some cups of tea...
There is something that could not be done using a script.
