We have "slotDeletedObject", I need "slotBeforeDeleteObject"
freedman
Post by freedman »
I can't figure out a way to trap prior to FreeCAD deleting the object on using the delete key. Using slotDeletedObject is after the event of deleting. I tried capturing the key press but that is also after the event. SlotBeforeChangeObject fires early but I don't know how to recognize if the action is a delete. It looks like I need "slotBeforeDeletedObject" and there is no such slot.
What I want: If the user presses the delete key I want to be able to code if they should under the current situation. I wouldn't have a problem with using clearSelection to stop the processes but I just don't know how to set the trap.
openBrain
Re: We have "slotDeletedObject", I need "slotBeforeDeletedObject"
Post by openBrain »
What kind of object?
Any object or specific ones of a document?
Is the slot the one of DocumentObserver (Gui or App?) or of DocumentObjectObserver?
freedman
Re: We have "slotDeletedObject", I need "slotBeforeDeleteObject"
Post by freedman »
Edit: I would want to allow other objs and some Bodies to be deleted so I do need to filter the object i.e. look for custom properties.
The object being deleted is a Body in PartDesign. The macro selects a Body (hightlighted in the tree and 3D), I want to be able to block if the user clicks delete.
Here are the last few lines of the macro:
visCB = cbToolBox()
v = Gui.ActiveDocument.ActiveView
o = visCB.ViewObserver()
s = o.SelObserver()
FreeCADGui.Selection.addObserver(s)
do = visCB.DocObserver()
App.addDocumentObserver(do)
freedman wrote: Thu Jun 01, 2023 9:30 pm ...
There is not an onDelete() method somewhere?
Regards.
Workshop_Notes
Post by Workshop_Notes »
freedman wrote: Thu Jun 01, 2023 4:43 pm I tried capturing the key press but that is also after the event.
Can you capture the keypress, and if the key pressed is 'delete', immediately issue an 'undo' action, and then proceed? In short, go past where you want to be and then back up one step.
freedman
Post by freedman »
I tried that first and it works .
I would be depending on the undo to work perfectly, could be issues with many depenencies and the Delete tears up the model.
freedman wrote: Sat Jun 03, 2023 3:36 am
If there is an onDelete property you could simply intercept his action and substitute his content with your desired action.
On Qt there is some examples of intercepting onClose() actionas example to avoid to close a dialog using the "small x" that many OS used to close a Window.
Same work if an object have the onDelete() you could not pass the action or emit a dialog to confirm, like "are you sure you want to delete me?".
More object oriented and robust than intercept keypress or Gui Commands.
But it depends on what the object is and if it have such s method. @wmayer?
Regards.
freedman
Post by freedman »
I think I found it in a search.
viewtopic.php?t=11818#p94994
Thanks, I will report back.
freedman
Post by freedman »
Here is the code from the prior post, I can't get it to work. I get a no attribute "proxy". I tried this code without the proxy and the class fires once at startup but never again. I don't understand.
obj = FreeCAD.ActiveDocument.addObject("Part::FeaturePython",partName)
class MyViewProviderProxy:
#    print("1")
    def onDelete(self, feature, subelements): # subelements is a tuple of strings
#    print("2")
        return True # If False is returned the object won't be deleted
obj.ViewObject.Proxy = MyViewProviderProxy()
freedman wrote: Sun Jun 04, 2023 6:54 pm ...
As usual with partial code and too minimal code fragments is hard to tell and even experiment with code.
A little standalone script that load and executed will show the problem could be of some help.
Regards.
