Pathetic newbie question
DAHunt55
Post by DAHunt55 »
I used to use Solidworks 07, haven't done any 3d modeling since 2006. How do you rotate a part in FreeCad? I used to have a SpaceBall, now using a conventional mouse. Thanks in advance!
Re: Pathetic newbie question
There are various possibilities:
- use Std Transform
- use the Placement dialog
- change the Placement values in the Data tab.
Please note: if an object is attached, you have to change the AttachmentOffset and not the placement, which is then calculated.
GeneFC
Post by GeneFC »
DAHunt55 wrote: Fri Jun 02, 2023 9:39 pm now using a conventional mouse
Take a look at https://wiki.freecad.org/Mouse_navigation
Various types of movement, with instructions about use. Pick one you like.
Gene
jfc4120
Post by jfc4120 »
I just use draft rotate, depending on what I am rotating.
In FreeCAD wiki there is also a document to help you in the transition between SolidWorks and FreeCAD if I remember correctly.
