Updating old theme's
MisterMaker
Re: Updating old theme's
Post by MisterMaker »
On further exploration on this issue I come to the conclusion the gray out is not dark enough for a dark theme.
I read on QT website:
The default engine scales pixmaps down if required, but never up, and it uses the current style to calculate a disabled appearance.
But if I compare dark theme with no theme/light the gray out icons are the same:
dark vs no stylesheet
paddle
Post by paddle »
MisterMaker wrote: Thu May 25, 2023 8:09 pm But there are a lot of icons that have white and maybe a color, like the new icon or almost all sketch icons.
Yes but colorblinds with a single channel off, do not see red color gray. They see it green (kind of).
MisterMaker
Made a github issue about it.
Probably gonna ask on Qt forum on how this should work.
https://github.com/FreeCAD/FreeCAD/issues/9673
MisterMaker
I updated my EPD theme with your feedback: viewtopic.php?t=68973
I also removed some borders from spinbox and that other one.
MisterMaker
This is how it looks now for the darker blue:
MisterMaker
Code attached!
Darker-blue_new.zip
(9.49 KiB) Downloaded 47 times
MisterMaker
Managed to make a PR, although it somehow took my gitignore with it....
https://github.com/FreeCAD/FreeCAD/pull/9715
Highlight colors used are as followed:
darker
blue #2053c0 #1b3774
green #74831d #6d8000
orange #b28416 #996b00
pink #b216a0 #770069
dark
blue  #4882ff #3f7cff
green #a1bd00 #819700
orange #c8951c #926600
pink #bc1cc8 #920077
light
blue #8cb0ff #b0c9ff
green #B7D300 #E1FF00
orange #ffb916 #ffe098
pink #f892ff #ffbff3
MisterMaker
I made a github repro with all the new theme's so it can be installed true the addon manager.
I don't think any new updates to the theme's get pushed to any clients like built-in addons are?
https://github.com/MisterMakerNL/Freeca ... emes-beta/
I am also open for the idea to just remove all build-in theme's and just point to the addon manager to get theme's. Since the addon manager does a great job in keeping it all up-to-date.
I tried adding the repo to the addon manager and installing but it doesn't work
Screenshot 2023-06-30 190803.png (12.3 KiB) Viewed 3449 times
app4soft
Post by app4soft »
adrianinsaval wrote: Fri Jun 30, 2023 11:09 pm I tried adding the repo to the addon manager and installing but it doesn't work
The issue was related to package.xml, that had no defined default branch (which should be set as main), and Addon Manager decides that default branch is master (which was default on GitHub, for years).
So, Addon Manager tried to reach master branch (ignoring even custom repo branch setting), then GitHub redirected it to main and since then there is some issue with Addon Manager that does not fully detected this redirect, but still could install such addon. That is in part Addon Manager issue.
BTW, I just helped to fix this and @MisterMaker already updated repo: https://github.com/MisterMakerNL/Freeca ... /tree/main
Before install cleanup Addon Manager cache: ~/.cache/FreeCAD/Cache/AddonManager
Then restart FreeCAD, add custom repo into Addon Manager (do not forget set main branch), launch Addon Manager and install theme.
:idea: Commissions Open! https://bmc.link/app4soft/commissions
Making 2D/3D CAD with FreeCAD, LibreCAD & SolveSpace apps.
YouTube: https://youtube.com/@app4soft
BMC: https://buymeacoffee.com/app4soft
Patreon: https://patreon.com/app4soft (all FREE)
