knots and direction of B-Spline
I have just started to work with B-Splines and wonder if there is an easy way to walk along a B-Spline, find all knots and their direction (probably their derivative). Your help will be much appreciated
thanks
thanks
Re: knots and direction of B-Spline
Easy is in the eye of the beholder.
Create a single B-Spline in Sketcher and close. Select it and send to the python console with ctrl-shift-P.
bsp is your BSpline object. Command completion will give you the Properties and methods - like bsp.KnotSequence or bsp.getPolesAndWeights()
Unfortunately help(bsp) is truncated, but
bsp = sub.Curve
def fullhelp(obj):
list = [(getattr(obj, d), d) for d in obj.__dir__() if d[0] != '_' and not d[0].isupper()]
[help(l[0]) for l in sorted(list, key = lambda s: s[1])]
fullhelp(bsp)
[code]
gets the internal documentation.
There are methods in OCCT that do that, named D0, D1 etc. I'm pretty sure they are exposed in Part::Geometry as well.
My latest (or last) project: B-spline Construction Project.
Some properties of the <BSplineCurve object>
Help on built-in function getD0:
getD0(...) method of Part.BSplineCurve instance
Returns the point of given parameter
Help on built-in function getD1:
getD1(...) method of Part.BSplineCurve instance
Returns the point and first derivative of given parameter
Help on built-in function getD2:
getD2(...) method of Part.BSplineCurve instance
Returns the point, first and second derivatives
Help on built-in function getD3:
getD3(...) method of Part.BSplineCurve instance
Returns the point, first, second and third derivatives
Help on built-in function getDN:
getDN(...) method of Part.BSplineCurve instance
Returns the n-th derivative
That is an annoying limitation of the FreeCAD Gui. FreeCADCmd will give you the full help, however:
bin/FreeCADCmd
FreeCAD 0.21.0, Libs: 0.21.0R33238 (Git)
(c) Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2023
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
[FreeCAD Console mode <Use Ctrl-D (i.e. EOF) to exit.>]
>>> import Part
>>> import readline
>>> help(Part.BSplineCurve)
Cheers,
Markus
Markus
thanks for your input, that helped me.
However, I could not find anything what kind of parameter is require when calling D0 or D1. I want to call the points (D0) and their derivative D1.
I do get the points directly without any parameters using BSP03.Shape.Curve.NbPoles
BSP03.Shape.Curve.NbPoles is an integer - the number of Poles of the BSpline.
In FreeCAD every Curve that describes the geometry on an Edge is defined parametrically by equations. For instance, a circle at the origin, of radius R in the XY-Plane is
x(t) = R * cos(t)
y(t) = R * sin(t)
z(t) = 0
Straight lines, conics etc. likewise, are defined by an algebraic parameterization. You find a point on the curve with parameter t with
edge.Curve.value(t)
p, t = edge.Curve.getD1(t)
Moving on to BSplines. A BSpline curve bsp is parameterized by a sequence of polynomials of degree bsp.Degree. The entire parameterization is divided into intervals t0 <= t1 <= t2 <= ..... <=tn given by bsp.KnotSequence (aka a knot vector). In each interval, there is a different polynomial whose values are influenced by neighboring Poles (aka control points), given by bsp.getPoles(). In the sketcher, it's the poles/control points you move around. They are the handles in Adobe Illustrator.
By manipulating the multiplicities (equality of neighboring t values in the knot vector), you can force a BSpline to go through the corresponding control point, but only at the cost of smoothness at the connection point. This is typically always done at the end-points of the BSpline, and can be done at interior points.
Freya Holmer made an awesome video about Bezier Curves (which are a particular kind of BSpline), showing how they work. https://www.youtube.com/watch?v=aVwxzDHniEw Do some googling, there's lots out there about BSplines. I have a 300 page book about them!
If you have a specific thing you want to do with your BSpline, we can likely point you at the method that does the job.
thanks for your clear explanation and your references (video). This helped me a lot. I have never been in contact with B-Splines in the past.
Seems to be a great tool
