Screen_Wiki macro
mario52
Re: Screen_Wiki macro
Post by mario52 »
Hi
have you tried selecting the object ?
jimmihenry wrote: Sun May 28, 2023 9:51 pm Mostly a number of pictures is key...
ok
can you share the led file please
mario
jimmihenry
Post by jimmihenry »
Hi Mario,
if i select the object i have no problem to create the images. The problem is there are always more than one objects. To rotate the hole object set i have to make a compound. The compound is tricky, looks ugly if transparent parts are involved etc... I have attached the LED as requested.
Thank you for your trouble.
Cheers
P.S. I would like to mention i am preparing every model before creating the images.
LED_HANUA_HH-1000CRGBC810C_Round_MKII_RGB_D10.0mm.FCStd
(719.37 KiB) Downloaded 18 times
mario52
Post by mario52 »
Hi
jimmihenry wrote: Mon May 29, 2023 5:10 pm
you can testing the new version "00.06b" "2023/06/27" Macro_Screen_Wiki
adding :
* choice number image ,
* button test rotation,
* button visualize the point rotation, (1out of two ?? )
* code center rotation on center screen (View3D) Programmatically setting the center of rotation
tell me your feedback thanks
mario
jimmihenry
mario52 wrote: Tue Jun 27, 2023 9:42 am Hi
mario
That's exiting! But i can't find the download "00.06b"...? Wiki provides the icon "Macro_Screen_Wiki.png". Only the icon twice. Image
https://wiki.freecad.org/index.php?titl ... creen_Wiki
mario52
Post by mario52 »
Hi
jimmihenry wrote: Tue Jun 27, 2023 1:34 pm But i can't find the download "00.06b"
with AddonManager or directly on Gist Macro_Screen_Wiki.FCMacro
mario
jimmihenry
@mario52 Thank you got it!
Tried also AddonManager, it says i can have v00.05...
mario52
Post by mario52 »
Hi
@chennes problem with AddonManager maybe refresh the local cache uninstall and install again
i see "Version 00.06b installed" did you execute the macro ?
mario
jimmihenry
mario52 wrote: Wed Jun 28, 2023 9:53 am Hi
mario
Yea i did.... Its fantastic :mrgreen:.
Rotation on 3D view works as expected, does not climb the Z axsis.
One issue i had was that the second Image was cut?! That's not bueno.
But this happened to the previous version as well...
Oh i almost forgot THANK YOU ! :D
Cut Image 1_Animate_02_Z_010-0000_Current.png (82.93 KiB) Viewed 1060 times
ScreenWiki_v.00.06b images 36+1.webp (1017.24 KiB) Viewed 1060 times
mario52
Post by mario52 »
Hi
good ... thanks @wmayer
for the image maybe wmayer can know why ? i have the same too
mario
