open FreeCAD and select for ex. French in the Preferences.
close FreeCAD.
reopen it, FreeCAD is in French. normal.
go to Edit/Preferences, in the left side bar, you read Import-Export.
select a wb, Part or Part Design.
now go back to Edit/Preferences, Import-Export is translated in Importer-Exporter.
strange, no?
translation of Import-Export not automatic
Re: translation of Import-Export not automatic
The preferences sidebar translation context was wrong for several of the workbenches until this past week: it's possible that the Import/Export string is also in the wrong context. @kaktus can you make a GH issue for this (if you haven't already)? I'm going to be relatively unavailable for a week or two here and I don't want it to get lost.
I see no problem in helping David create a ticket on GitHub.
I will look into this problem as well.
wierny padawan mistrza arturromarr
Twórca polskiej wersji Wiki dla FreeCAD, współwórca polskiej wersji GUI.
"Cierpliwym być musisz, by wiedzę zgłębiać tajemną, gdyż ciemna strona mocy niszczącą i silną jest".
huuhh
Actually FreeCAD's behavior is intriguing.
I start the program look into preferences I see `import-Export` (no translation).
I select the workbench `Mesh` then look into preferences and see `Import-Eksport` (string translated).
Loading some workbenches affects the fact that this string is reloaded to translated.
I wonder if this is an exception or if there are more such anomalies.
fixed with
thank you to the right person
OS: Ubuntu 22.04.2 LTS (LXQt/Lubuntu)
Version: 0.21.0.33303 (Git) AppImage
Hash: 5b075a9938b78076fdde9034de4a05685e42690e
Python 3.10.11, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: French/France (fr_FR)
* Help 1.0.3
