ModuleNotFoundError: No module named 'PyQt5.QtWidgets'
_Nemo
Post by _Nemo »
Hi all, I have a strange problem: when I type from PyQt5.QtWidgets import QWidget in the python console of FreeCAD 0.19.4 I get an error:
ModuleNotFoundError: No module named 'PyQt5.QtWidgets', but in QtWidgets'
But the import is successful in the FreeCAD 0.19.4 path using the terminal, what is the reason for this?
Syres
Re: ModuleNotFoundError: No module named 'PyQt5.QtWidgets'
Post by Syres »
Are you using self compiled or an AppImage? I thought the standard on 0.19.x was:
from PySide2.QtWidgets import QWidget
_Nemo
Post by _Nemo »
Syres wrote: Tue May 23, 2023 10:32 am Are you using self compiled or an AppImage? I thought the standard on 0.19.x was:
Thank you for your reply! The function I need to realize is not supported by pyside, so I used pyqt.
Does FreeCAD 0.19 not support pyqt?
Syres
Post by Syres »
_Nemo wrote: Tue May 23, 2023 10:45 am Does FreeCAD 0.19 not support pyqt?
Support is a big word, to be honest I'm not sure.
