warnings in weekly build 33263 win-conda
Piero69
Post by Piero69 »
@chennes
i keep having these two warnings when running FC and addonmanager, what are they? can be corrected?
07:32:35 Addon Developer Warning: Repository branch set in package.xml file for addon freecad.gears workbench (develop) does not match the branch it was fetched from (master)
07:32:39 libpng warning: iCCP: known incorrect sRGB profile
OS: Windows 10 build 19044
Version: 0.21.0.33263 (Git)
Hash: 864f99bf984c237ef38d9451fd6f3a5ec34e6eb4
Python 3.10.11, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: Italian/Italy (it_IT)
  * 3DfindIT 1.2.0
  * CurvedShapes 1.0.4
  * Curves 0.6.9
  * fasteners 0.4.56
  * freecad.gears 1.0.0
  * InventorLoader 1.4.0
  * QuickMeasure 2022.10.28
  * sheetmetal 0.2.63
  * Silk 0.1.3
chennes
Re: warnings in weekly build 33263 win-conda
Post by chennes »
For the freecad.gears warning: the developer of that addon needs to update their package.xml file (or they need to update the branch used in FreeCAD-Addons). The PNG warning is coming from libpng, which we don't really control -- someplace on the wiki there are macros using bad icon data. So we could try to hunt those down, but it's not easy to figure out which ones are the problem.
Chris Hennes
Pioneer Library System
Can we filter out the libpng warnings? They are not helpful to the user, at least we should move them to log level messages
chennes
Post by chennes »
I don't know -- is there a way to filter the report view? That warning is basically worthless.
Chris Hennes
Syres
Post by Syres »
chennes wrote: Mon May 22, 2023 12:45 pm someplace on the wiki there are macros using bad icon data. So we could try to hunt those down, but it's not easy to figure out which ones are the problem.
Assuming pngcrush is installed:
#!/bin/bash
FILES=$(find "$1" -type f -iname '*.png')
FIXED=0
for f in $FILES; do
    WARN=$(pngcrush -n -warn "$f" 2>&1)
    if [[ "$WARN" == *"PCS illuminant is not D50"* ]] || [[ "$WARN" == *"known incorrect sRGB profile"* ]] || [[ "$WARN" == *"iCCP: Not recognizing known sRGB profile"* ]]; then
        pngcrush -s -ow -rem allb -reduce "$f"
        FIXED=$((FIXED + 1))
    fi
done
echo "$FIXED errors fixed"
Successfully corrected a PNG file on my Linux Mint 20.3 box in subfolder to ensure it was recursive. If you want a test 'faulty' PNG file, I used https://raw.githubusercontent.com/Geosc ... 3/icon.png
@wmayer @abdullah I believe some filters where created for the notification system, can we filter out libpng warnings from report view too?
wmayer
Post by wmayer »
The filters passed to QLoggingCategory::setFilterRules only work when the function qCWarning() is used where the first argument is the category string. When qWarning() is used instead then with Qt it's not possible to filter the warning. In this case we must implement our own filtering mechanism.
wmayer
Post by wmayer »
Possibly the PNG reader uses the category string: qt.gui.imageio
https://github.com/qt/qtbase/blob/6a4af ... r.cpp#L237
Do we have a PNG file that triggers the warning in order to see if with ignoring "qt.gui.imageio" the warning can be filtered?
chennes
Post by chennes »
According to the poster above, this PNG is faulty:
Chris Hennes
wmayer
Post by wmayer »
OK, thanks. I can confirm the warning when loading the file but unfortunately the warning hasn't the context string "qt.gui.imageio"
