[Sketcher] Tune dimension position with scripting.
Hello, I've done a quick search on the forum, using a search engine, (to circumvent forum search limitations).
But I've not found a way to tune the position of the dimensions, with Gui is easy to drag the constraint dimension in a proper place to avoid overlap with other dimensions, with scripting nothing is echoed.
There is a way to tune this dimension, position maybe even only to left or right to avoid overimposed lengths that will make the editing difficult.
from this:
to this:
Re: [Sketcher] Tune dimension position with scripting.
onekk wrote: Wed May 03, 2023 10:21 am But I've not found a way to tune the position of the dimensions,
You may try to check what's in the Document.xml file.
Thanks I will try to see if something could be found there.
