Part FeaturePython Shape from a file.
keithsloan52
Post by keithsloan52 »
I wish to create a Part FeaturePython Object where the Shape is read from a brep file.
I have a property that is the path of the file but if I try and set the Shape with self.Object.Shape.read(path) in the def __init___
or an equivalent in createGeometry I get an error
 File "/Users/keithsloan/Library/Application Support/FreeCAD/Mod/GDML/./freecad/gdml/GDMLObjects.py", line 5159, in __init__
<class 'ReferenceError'>: This object is immutable, you can not set any attribute or call a non const method
Re: Part FeaturePython Shape from a file.
Did you try:
load_obj = Part.Shape()
load_obj.read(path)
self.Object.Shape = load_obj
not tested!
Hope it helps.
Kind Regards
keithsloan52
onekk wrote: Sun Apr 02, 2023 12:32 pm Did you try:
load_obj.read(path)
not tested!
Hope it helps.
Kind Regards
Better but get
14:54:52  <Part> ViewProviderExt.cpp(1270): Cannot compute Inventor representation for the shape of Dipole#GDMLbrepPart_DC2: Bnd_Box is void
If I print out the bound box and try and use it to set Shape.BoundBox with the following
        loadShape = Part.Shape()
        loadShape.read(path)
        print(f"brep BoundBox {loadShape.BoundBox}")
        self.Object.Shape = loadShape
        self.Object.Shape.BoundBox = loadShape.BoundBox
I get ( Note BoundBox is VERY large )
15:00:37  Path exists True
15:00:37  brep BoundBox BoundBox (1.79769e+308, 1.79769e+308, 1.79769e+308, -1.79769e+308, -1.79769e+308, -1.79769e+308)
15:00:37  <Part> ViewProviderExt.cpp(1270): Cannot compute Inventor representation for the shape of Dipole#GDMLbrepPart_DC2: Bnd_Box is void
15:00:37  Traceback (most recent call last):
  File "/Users/keithsloan/Library/Application Support/FreeCAD/Mod/GDML/./freecad/gdml/importGDML.py", line 96, in open
    processGDML(doc, True, filename, True, False)
  File "/Users/keithsloan/Library/Application Support/FreeCAD/Mod/GDML/./freecad/gdml/importGDML.py", line 3066, in processGDML
    parseVolume(doc, volDict, part, world, phylvl, 3)
  File "/Users/keithsloan/Library/Application Support/FreeCAD/Mod/GDML/./freecad/gdml/importGDML.py", line 2044, in parseVolume
    expandVolume(doc, volDict, parent, name, phylvl, displayMode)
  File "/Users/keithsloan/Library/Application Support/FreeCAD/Mod/GDML/./freecad/gdml/importGDML.py", line 2407, in expandVolume
    parsePhysVol(
  File "/Users/keithsloan/Library/Application Support/FreeCAD/Mod/GDML/./freecad/gdml/importGDML.py", line 1978, in parsePhysVol
    expandVolume(doc, volDict, part, volRef, phylvl, displayMode)
    parsePhysVol(
  File "/Users/keithsloan/Library/Application Support/FreeCAD/Mod/GDML/./freecad/gdml/importGDML.py", line 2399, in expandVolume
    processVol(doc, vol, volDict, parent, phylvl, displayMode)
  File "/Users/keithsloan/Library/Application Support/FreeCAD/Mod/GDML/./freecad/gdml/importGDML.py", line 2359, in processVol
    GDMLbrepPart(part, path)
  File "/Users/keithsloan/Library/Application Support/FreeCAD/Mod/GDML/./freecad/gdml/GDMLObjects.py", line 5162, in __init__
<class 'AttributeError'>: Attribute 'BoundBox' of object 'ComplexGeoData' is read-only
There is no a fromBREP() method in Part.Shape? Or something similar.
Sorry no experiment as I'm far from a computer.
keithsloan52
Okay found the problem the brep file was not valid.
It was created by selecting a Part and then exporting to Brep, that obviously does not work. If I select an object in a Part and then export that to Brep it creates a valid brep.
I guess to make it more general I need to select all Objects in a Part, make a Compound and then export that. Time to put think hat on again.
