Thank you Papyblaise that looks terrific. I will examine your file tomorrow.papyblaise wrote: ↑Fri Mar 31, 2023 7:44 am I took your file to modify the flow and especially the shape of the duckbill using only arcs of circles to allow the subsequent welding radius
Loft Problem [SOLVED]
Re: Loft Problem [SOLVED]
After a couple of hours trying to figure this out I almost gave up but thanks to our friend at Joko EngineeringLaurie Hartley wrote: ↑Fri Mar 31, 2023 10:41 amThanks once again Bance - I will have another attempt tomorrow.
https://youtu.be/g487DTBOdjU
I realise where I was going wrong - I was trying to use the mirror tool after I had created the Multitransform
For the benefit of anyone who has similar difficulties as how this works here are the steps I took:-
1. Selected the pad and additive loft using the control key
2. Selected the Multitransform icon
3. A window with two panes opened above which was a green message stating the transformation had succeeded
4. I right clicked in the lower of the two windows and chose add mirrored transformation
5. Chose as the plane "vertical sketch axis" then "OK"
6. Right clicked on the lower pane again
7. Chose as the plane "horizontal sketch axis" then "OK"
Very simple really - that's probably why I struggled with it - complication is my forte
Thank you Bance, Thomas and Papyblaise for helping me. I appreciate it.
- Screenshot_Mirror.png (198.22 KiB) Viewed 226 times
And it's all written up in the wiki
