Hole Pattern
EgeJuul
Hole Pattern
Post by EgeJuul »
Hey
I want to make a item, retangular with rounded corners, thats no problem, then i want to make holes ofset from the edeg al the way round in eaqual apacing. Can i do that our do i have to construct them all :?:
Bedst regards Ege Juul Nielsen
Re: Hole Pattern
Hi and welcome to the forum!
Please tell us a bit more: which workbench do you use (Part, PartDesign), and upload an example of what you try to do.
On first sight: what you want to do sounds like asking for trouble caused by the topological naming problem.
thomas-neemann
Re: Hole Pattern
Post by thomas-neemann »
EgeJuul wrote: Wed Mar 29, 2023 8:18 am ...
If you want, I can link you to a video here or via pm where it can be seen
Shalmeneser
Re: Hole Pattern
Post by Shalmeneser »
Draft_PathArray ?
You should provide a Minimal Working Example (MWE).
Syres
Re: Hole Pattern
Post by Syres »
Attached is a fully parametric file achieving IMHO what you asked for.
The only changes you need to make are the dimensional constraints in Plate_Sketch, size of hole in Hole_Sketch, the thickness of the plate in Plate_Extrude>LengthForward and the Expression in Holes_PathArray > Count >
trunc(Sketch002.Shape.Length / 100)
where 100 is spacing in millimetres between hole centres inorder to calculate the number of holes. I'm sure you'll try and break it but give it a whirl.
OS: Linux Mint 20.3 (X-Cinnamon/cinnamon)
Version: 0.20.2.29690 (Git)
Branch: releases/FreeCAD-0-20
Hash: 05a5df264a52e5799c8a4de90be8c1cb5d00ed1e
  * Silk 1.0.0
  * A2plus 0.4.60k
  * CurvedShapes 1.0.4
  * MakerWorkbench 1.0.1
  * freecad.gears 1.0.0
  * Curves 0.6.8
  * PieMenu 1.2.4
  * toSketch 1.0.1
  * Plot 2022.4.17
  * AirPlaneDesign 0.4.0
  * fasteners 0.4.54
  * sheetmetal 0.2.63
Edit: trunc is a better function than round as it always goes towards zero.
OffsetHolesInRectangle.FCStd
(21.25 KiB) Downloaded 8 times
Workshop_Notes
Re: Hole Pattern
Post by Workshop_Notes »
Syres wrote: Wed Mar 29, 2023 5:52 pm Attached is a fully parametric file achieving IMHO what you asked for.
Please, the 'count' in the path array is 11 but only 10 holes are shown.
It is my understanding that when you do a path array, an object is placed at both the beginning and end of the path. When the path is a closed loop, will that not result in a duplicate object?
If it is true that there is a duplicate, is it undesirable that this should be so?
Thanks.
Roy_043
Re: Hole Pattern
Post by Roy_043 »
Workshop_Notes wrote: Wed Mar 29, 2023 9:33 pm the 'count' in the path array is 11 but only 10 holes are shown.
I see 11 holes.
Workshop_Notes wrote: Wed Mar 29, 2023 9:33 pm will that not result in a duplicate object?
No.
