(WORKAROUND) incomplete ifc export. operating error?
thomas-neemann
Re: (WORKAROUND) incomplete ifc export. operating error?
Post by thomas-neemann »
bernd wrote: Tue Mar 28, 2023 10:04 am ...
ok
thomas-neemann
but as at the beginning there seems to be a problem with compounds. here is a file from solids
1416.FCStd
(42.13 KiB) Downloaded 117 times
that is exported as ifc
1416.ifc
(14.8 KiB) Downloaded 114 times
thomas-neemann
these 2 possible types of faces are exported as ifc
1753.FCStd
(8.81 KiB) Downloaded 122 times
1753.ifc
(4.41 KiB) Downloaded 114 times
thomas-neemann
mesh did not work for a more complex file. there a draft upgrade to block, then converting to solid in curves helped before the ifc export. so everything should work
thomas-neemann
apparently there are problems with the face export on top plane. but draft block with curves works solid here too
1753ko.FCStd
(9.83 KiB) Downloaded 125 times
bernd
Post by bernd »
the face export problem might better go into a separate topic ...
In the regard of your compound solid export ... For me all objects are in the ifc. It seams some placement is wrong on export and thus one of the objects moves inside the other and it looks like something is missing ... Attached screen from your ifc attached to your post ...
thomas-neemann
video from workaround
viewtopic.php?p=671821#p671821
bernd
Post by bernd »
made a new separate topic for the placement problem of the nested objects viewtopic.php?t=77785
