From my understanding the STEP export function uses the global coordinate system of a part.
Is it possible to use another coordinate system as base coordinate system for the export?
Johnny
Step Export using local coordinate system
- thomas-neemann
Re: Step Export using local coordinate system
I don't know, but I would just use draft move to move the part to be exported to the global origin
I'm not quite sure what this option does, but you may try Preferences->Import-Export->STEP->Export->Export single object placement.Johnny Geling wrote: ↑Tue Mar 28, 2023 8:03 am Is it possible to use another coordinate system as base coordinate system for the export?
You may have to use a step import or export before going to preferences in order to make the preferences available.
I used this setting. No luck.chrisb wrote: ↑Tue Mar 28, 2023 9:04 amI'm not quite sure what this option does, but you may try Preferences->Import-Export->STEP->Export->Export single object placement.Johnny Geling wrote: ↑Tue Mar 28, 2023 8:03 am Is it possible to use another coordinate system as base coordinate system for the export?
It would help when multiple coordinate systems are exported to the STEP format.
In that case I can reposition in the receiving application.
Johnny
