hello, please am using freecad 0.20.2 appimage on linux (pop os). I am trying to run cfdof simulation. After setting up, I tried to run the solver but it is giving me an error "here are not enough slots available in the system to satisfy the 4
slots that were requested by the application:
/usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/bin/renumberMesh
Either request fewer slots for your application, or make more slots
available for use.
A "slot" is the Open MPI term for an allocatable unit where we can
launch a process. The number of slots available are defined by the
environment in which Open MPI processes are run:
1. Hostfile, via "slots=N" clauses (N defaults to number of
processor cores if not provided)
2. The --host command line parameter, via a ":N" suffix on the
hostname (N defaults to 1 if not provided)
3. Resource manager (e.g., SLURM, PBS/Torque, LSF, etc.)
4. If none of a hostfile, the --host command line parameter, or an
RM is present, Open MPI defaults to the number of processor cores
In all the above cases, if you want Open MPI to default to the number
of hardware threads instead of the number of processor cores, use the
--use-hwthread-cpus option.
Alternatively, you can use the --oversubscribe option to ignore the
number of available slots when deciding the number of processes to
launch."
please can someone help me through on how to change the number of slots?
cfdof workbench
Moderator: oliveroxtoby
Re: cfdof workbench
Do you want to change the number of slots your machine has available or the number of slots CfdOF requests?
Re: cfdof workbench
Gruß Herbert
- oliveroxtoby
Re: cfdof workbench
This should just mean that you need to reduce the 'Parallel Cores" in the CfdSolver object properties as it exceeds the number available on your machine. I'm a bit surprised there are not four cores available though.A.Ahmad wrote: ↑Mon Mar 27, 2023 4:35 pm hello, please am using freecad 0.20.2 appimage on linux (pop os). I am trying to run cfdof simulation. After setting up, I tried to run the solver but it is giving me an error "here are not enough slots available in the system to satisfy the 4
Re: cfdof workbench
Hi Oliver,
In my mind the prob ist based at changend pakge contend of OpenMPI. After installing openmpi1-devel (where i'm in mind i havn't installed it at older systems) multicore use runs.
Cfdof also needs openmpi1 (wich is a bit old ), - by default openSuse installs openmpi4, where is cfdof not working with.
I have had the same message at a two 6 cores/8 threads laptops and had to switch off multicore use to get a output.oliveroxtoby wrote: ↑Wed Apr 05, 2023 3:24 pm I'm a bit surprised there are not four cores available though.
Gruß Herbert
Re: cfdof workbench
Thank you all for your help, I did not visit may page for sometime, I was able to solve the problem by turning the parallel option at the cfdsolver data panel "false".
