Clear all dependent parameters
How to clear all dependent parameters of an object (or several objects) in a project at once? Cleaning manually turns out to be very long and you can miss something.
- Peek 2023-02-15 12-24.gif (435.52 KiB) Viewed 1131 times
Re: Clear all dependent parameters
Hello, this task can be achieved with a bit of python code
for i in App.ActiveDocument.Objects:
if i.isDerivedFrom("Part::Feature"):
if i.ExpressionEngine:
for j in i.ExpressionEngine:
i.setExpression(j[0], None)
App.ActiveDocument.recompute()
FreeCAD "macros" are just Python. You can save it in a file named mycoolcode.FCMacro or mycoolcode.py. Then you can execute it from the macro menu.
If you need it a lot you can also add it to one or more toolbars from the Tools>Customize menu.
It's worked!
And if you need to clear a specific object, is it enough to substitute its internal name instead of App.ActiveDocument.Objects? Or, the syntax will be much more complicated?
Here's what you really want (I hope):
import FreeCAD as App
from PySide import QtCore, QtGui
from PySide.QtGui import QLineEdit, QRadioButton
ExpObjects = []
class ExpressionRemover():
def __init__(self):
if len(i.ExpressionEngine) != 0:
ExpObjects.append(i.Name)
if len(ExpObjects) == 0:
App.Console.PrintWarning('There are no Expressions to be removed\n')
else:
self.dialog = None
self.s1 = None
# Make dialog box
self.dialog = QtGui.QDialog()
self.dialog.resize(300,120)
self.dialog.setWindowTitle("Expression Remover")
la = QtGui.QVBoxLayout(self.dialog)
t1 = QtGui.QLabel("Choose to remove All expressions or specific objects in the combobox")
la.addWidget(t1)
# Add radio buttons
self.radio1 = QtGui.QRadioButton("All Object Expressions")
self.radio2 = QtGui.QRadioButton("Specific Objects")
self.radio1.clicked.connect(self.on_radio1_clicked)
self.radio2.clicked.connect(self.on_radio2_clicked)
# self.radio2.setChecked(True)
la.addWidget(self.radio1)
la.addWidget(self.radio2)
self.expObjs = QtGui.QComboBox()
self.expObjs.addItems(ExpObjects)
self.expObjs.setObjectName("expObjs")
self.expObjs.currentIndexChanged.connect(self.check_validity)
la.addWidget(self.expObjs)
# Add OK / Cancel buttons
self.okbox = QtGui.QDialogButtonBox(QtGui.QDialogButtonBox.Ok | QtGui.QDialogButtonBox.Cancel)
la.addWidget(self.okbox)
QtCore.QObject.connect(self.okbox, QtCore.SIGNAL("accepted()"), self.proceed)
QtCore.QObject.connect(self.okbox, QtCore.SIGNAL("rejected()"), self.close)
button = self.okbox.button(QtGui.QDialogButtonBox.Ok)
button.setEnabled(False)
QtCore.QMetaObject.connectSlotsByName(self.dialog)
self.dialog.show()
self.dialog.exec_()
def check_validity(self,idx):
App.Console.PrintLog("Current index %d selection changed %s\r\n" % (idx,self.expObjs.currentText()))
button.setEnabled(True)
def on_radio1_clicked(self):
def on_radio2_clicked(self):
def proceed(self):
if self.radio1.isChecked():
self.close()
if self.radio2.isChecked():
if i.Name == self.expObjs.currentText():
self.close()
def close(self):
self.dialog.hide()
ExpressionRemover()
Tested using:
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.20.2.29177 +426 (Git)
Branch: (HEAD detached from 0.20.2)
* A2plus 0.4.60f
* Alternate_OpenSCAD 1.0.0
* Assembly3 0.11.4
* CfdOF 1.20.4
* Curves 0.6.6
* fasteners 0.4.54
* fcgear 1.0.0
* freecad.xray 2022.4.17
* FreeCAD_Turning_Addon 0.1.0
* Help 1.0.3
* Manipulator 1.5.0
* Plot 2022.4.17
* Render 2023.2.2
* sheetmetal 0.2.59
* Silk 1.0.0
* timber
Edit: I even made an icon for your toolbar
- ExpressionRemover.svg
- (10.28 KiB) Downloaded 18 times
This is exactly what was needed - your actions were ahead of my thoughts)
Can I somehow try to thank you?
No need for special thanks, it's all part of the community chipping in and anyway it gave my brain a little workout which is no bad thing.
