Unable to unfold in sheet metal
Hello
Freecad 0.20.2
File attached
When I select a face, only the face is unfold, not the complete part
Any help will be really appreciated
Freecad 0.20.2
File attached
- C520-210-pliage.FCStd
- (46.92 KiB) Downloaded 12 times
Re: Unable to unfold in sheet metal
We had this before, it comes from the miters added in Sketch001/Pocket. It works for small angles (e.g. 5°) but for your your bigger ones.
The object unfolds here:
OS: Windows 8.1 Version 6.3 (Build 9600)
Version: 0.21.0.32198 (Git)
Hash: f51b2156f35399cab38eef1e957a59ad5a11de66
Python 3.8.16, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: English/United States (en_US) [ OS: Dutch/Netherlands (nl_NL) ]
* sheetmetal 0.2.59
- C520-210-pliage_unfolded.FCStd
- (81.48 KiB) Downloaded 5 times
You should provide your full version info (follow link in red banner) : we don't know your SheetMetal version.
I'm guessing you've purposely not upgraded which is wise, I think I've a solution to the code regressions brought in version 0.2.61 but I need to spend some time testing to ensure I don't make things worse.
Edit: This is the code fix that I need to do the testing on https://github.com/shaise/FreeCAD_Sheet ... al:patch-5
Thank you
FreeCAD_0.20.2-2022-12-27-conda-Linux-x86_64-py310.AppImag
sheet metal 0.2.61
I undestand the problem could be solved with sheet metal 0.2.59
I will try to come back to 0.2.59
sheet metal 0.2.61
OS: Mageia 7 (WindowMaker/WindowMaker)
Version: 0.20.2.29603 (Git) AppImage
Branch: (HEAD detached at 0.20.2)
Locale: French/France (fr_FR)
* fasteners 0.4.54
* A2plus 0.4.60i
* workfeature-macro
* sheetmetal 0.2.61
Thank you Roy_043, I will use your unfold until version sheet metal 0.2.61 will be improved
(it seems not so easy for me to come back to an previous version)
I've submitted what really is a workaround to the workbench author that basically tries the code from late 2022 and if not falls back to the old code. That and a DXF/SVG export function in the dialog box so it could save a little time for those sending to laser cutter.
https://github.com/shaise/FreeCAD_SheetMetal/pull/268
@OlivierC the Sheetmetal workbench has been upgraded to 0.2.62, it would be appreciated if you could update, test and give constructive feedback.
Edit: As you've made manual changes to the installation you might have to remove it and then install from scratch.
