How to find "wire not closed" problems?
kzembower
Post by kzembower »
Hello, all,
I'm stuck with the 'wire not closed' error, and would like to fix it myself. I've found lots of links to this forum and others, with 'wire not closed' problems, but inevitably, someone just solves the problem for the OP without revealing how they found it (not just how they fixed it).
How do you find the problem area causing the 'wire not closed' error? So far, I've tried manual inspection, but all the points look connected to me. I've also tried moving the lines around, and seeing if anything comes undone, but without success. I've tried box-selection over intersections to select the vertices and choosing coincident constraints, but that didn't seem to do anything.
I'm deliberately not posting my file here, because I don't want someone to fix it for me just yet. I want someone to teach me how to fish. I'll post it later if I try to follow any suggestions and still can't find the problem.
Thanks for any help or advice you can provide.
-Kevin
Roy_043
Re: How to find "wire not closed" problems?
Post by Roy_043 »
There is a lot of experience in it and you tried already some of the well known suspects.
One more is:
1st step: count the elements in the list and in 3D view
2nd step: if there are too many elements in the list, walk over them and chek for invisibles (more likely) or doubles (less likely).
drmacro
Post by drmacro »
As noted the Validate sketch tool is the "after the fact" tool.
The better workflow is to lay down the basic outline (Polyline tool is really good for this) and before applying dimensional constraints, try to "wiggle" the lines. If if any vertexes come apart, hit them with a coincident constraint. Then proceed to constrain further.
There was (not sure if it's still there) a "wiggle" macro in Addon manager. 8-)
Though I don't use the wiggle, it can cause a mess. I recommend the "better workflow" described above.
drmacro wrote: Sat Mar 18, 2023 4:56 pm There was (not sure if it's still there) a "wiggle" macro in Addon manager. 8-)
It's ShakeSketch, but be warned! If you apply it too early in the process it destroys the complete layout, because it keeps only the existing constraints. So if you start with a reasonable polyline and use ShakeSketch, you can end with a completely scrambled set of lines which are just connected.
drmacro
Post by drmacro »
chrisb wrote: Sat Mar 18, 2023 5:46 pm
Caveat added. 8-)
kzembower
Post by kzembower »
Thanks so much to all who made suggestions. After a half dozen attempts with Validate Sketch, where I discovered overlapping lines, mostly, I finally got it to close.
I tried to fix my sketch with polylines, but I must have been doing something wrong, because, even though I thought I was getting an automatic constraint on endpoints, it seemed to only work correctly when I used individual straight line segments.
Oh, well... I'm unstuck now. Thanks, again, everyone.
-Kevin
drmacro
Post by drmacro »
kzembower wrote: Sat Mar 18, 2023 6:35 pm Thanks so much to all who made suggestions. After a half dozen attempts with Validate Sketch, where I discovered overlapping lines, mostly, I finally got it to close.
-Kevin
The polyline tool makes a new segment every time you click, so if you were tracing over what was there, you misunderstood what was being suggested.
The polyline tool automatically constrains the current segment to the next. The only one you have make sure of is the last vertex is constrained to the first.
Peek 2023-03-18 15-01.gif (515.14 KiB) Viewed 277 times
mario52
Post by mario52 »
Hi
chrisb wrote: Sat Mar 18, 2023 5:46 pm you can end with a completely scrambled set of lines which are just connected.
after completely scrambled you can use Undo/Redo button as object normal
i upgrade with :
FreeCAD.ActiveDocument.openTransaction(u"Shake Sketch")
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting. My macros on Gist.github here complete macros Wiki and forum.
To be clear: as helpful as Polyline is with its famous M key, it is not useful to correct a sketch.
Imagine you have drawn a polyline, and after finishing you don't end the sketch but want to move a corner. You click on the point, you move the mouse and the point doesn't follow. So you click again on the point and there you have already created a zero length line.
