@adrianinsaval
As of the last couple days the AUR build in Majaro is looking for an unmet dep of verdict.
I understand AUR works in Arch, but, it definitely still fails in Manjaro.
Is it as simple as installing the verdict package?
Manjaro AUR build looking for verdict
Re: Manjaro AUR build looking for verdict
yes, in order to build you need to install all declared dependencies. I had to add a couple extra dependencies for arch due to vtk 9.2 update, the update may not have reached manjaro yet but installing those packages won't hurt you. Use the -s argument when running makepkg so it installs those dependencies.
As of this post, installing vertdict made no difference. The update of freecad-git can't resolve verdict.adrianinsaval wrote: ↑Sat Mar 11, 2023 10:11 pm yes, in order to build you need to install all declared dependencies. I had to add a couple extra dependencies for arch due to vtk 9.2 update, the update may not have reached manjaro yet but installing those packages won't hurt you. Use the -s argument when running makepkg so it installs those dependencies.
I don't run makepkg, I assume that pamac does that somehow.
I also can't find a vtk higher than 9.1.
can you be more explicit? how are you trying to update? what error message do you get? As last resort if vtk 9.2 is not yet on manjaro you can edit the pkgbuild and remove the new dependencies from the list, verdict and adios2
I'll quote myself from the AUR page comments:
adrianinsaval wrote:For manajro users if the build suddenly stops working it usually is because the pkgbuild has been adapted to a recent arch update that hasn't reached you yet, archlinux is obviously priority here so for those cases it's up to you to rollback the pkgbuild to the previous state and make it work. In this page there is functionality to check what recent changes have been made to the pkgbuild: https://aur.archlinux.org/cgit/aur.git/ ... reecad-git rollback the changes in your local copy as necessary up to the last time it was working on manjaro, eventually manjaro will catch up and you will need the latest pkgbuild again.
