create mounting holes?
I created a round case for holding a piezo transducer (see attached pic). I would like to create a round lid with a mount hole (ie.,tabs) on each side. The lid will fit into the case, using mounting holes for a nut and bolt.
Do i create a round part with another part?? for the mounting tabs?
- Screen Shot 2023-02-04 at 12.20.44 PM.png (39.97 KiB) Viewed 683 times
Re: create mounting holes?
File / Full info / Drawing of your idea ?
No pain no gain.
No pain no gain.
Also mounts could also be square if it makes it easier to design.Shalmeneser wrote: ↑Sat Feb 04, 2023 5:39 pm File / Full info / Drawing of your idea ?
No pain no gain.
thankx very much
- Piezo Case.png (190 KiB) Viewed 631 times
- Piezo-case.FCStd
- (13.69 KiB) Downloaded 8 times
- Piezo-case_SHALM.FCStd
- (36.82 KiB) Downloaded 9 times
- Capture d’écran 2023-02-04 191253.jpg (37.1 KiB) Viewed 604 times
oooooh i see now, you don't attach mounting part to the edge but too the center of the lid. i overthink and get to complicated...Shalmeneser wrote: ↑Sat Feb 04, 2023 6:14 pm 1) Full version info (follow link in red banner).
2) Do not sketch upon face : TNP
thankx for taking time out...
ron
- papyblaise
you have intelligently placed the open face on the XY plane, so it is easier to place the sketch of the ear on this plane without risk of TNP
- Piezo-case PPB.FCStd
- (27.61 KiB) Downloaded 10 times
- Piezo-case PPB.JPG (20.68 KiB) Viewed 487 times
Je dirais même plus.
- Piezo-case_SHALM2.FCStd
- (29.47 KiB) Downloaded 6 times
Hi, still learning and great to learn by example. one more object i wanted to add to the case. I need to hole (rectangular) from the case in order to route wire from the case.
I tried using subtractive box? But doesn't extend through the case... Do i need to create a sketch for the box? No sure if I'm on the right thinking here.
thankx
- Piezo Case-with-wiring-outlet.png (199.47 KiB) Viewed 367 times
- Piezo-case_SHALM2-box-notch.FCStd
- (34.72 KiB) Downloaded 4 times
- papyblaise
change the Y from 15 to 14mm
In your last file, you should not use the solid for support : TNP
Do you need a Hole feature or just a Pocket ?
I usually don't use Primitive from PartDesign but sketch instead.
- Piezo-case_SHALM3.FCStd
- (46.07 KiB) Downloaded 6 times
- Capture d’écran 2023-02-05 184641.jpg (39.22 KiB) Viewed 309 times
