[solved] FreeCAD has selection filters?
FreeCAD has selection filters? I know there is such thing like Draft Snap but looks like it works only during wire creation? For example if I want to select only face, only edge or only vertex is there such filter for selection?
For vertex selection I added tool selectVertex. It works not in the way that face or edges are not selected, only vertices but if you select face or edge the nearest vertex will be selected. So, I guess it is little different than selection filters from other CAD systems? I was thinking to add more selection filters if there is no such thing at FreeCAD?
Darek
github.com/dprojects
Re: FreeCAD has selection filters?
But this is only part of Assembly workbench and it need to be installed? or there is such thing at FreeCAD base? I assume, if you created this filters, it means there is no such thing?
EDIT: Is there any docs page, tutorial with Assembly 4 icons, features descriptions? I was searching the internet for a while for those icons descriptions but looks there is no such thing? How they works? if I select edge it will select nearest Vertex? what if in the Edge Mode if I select something other than edge?
Darek
It is a trivial task to add it to any toolbar you choose. Here I've added it to the Global toolbar. Note I also added the wall tool from Arch workbench...very handy.dprojects wrote: ↑Sat Feb 04, 2023 10:19 amBut this is only part of Assembly workbench and it need to be installed? or there is such thing at FreeCAD base? I assume, if you created this filters, it means there is no such thing?
- Screenshot from 2023-02-04 05-59-26.png (87.47 KiB) Viewed 1682 times
But you probably have installed Assembly 4? Other question is how it works? To be honest I am not sure how the filters should work? If I select edge in the Vertex Mode this should select nearest Vertex or should leave nothing selected?
Where I can read about it how it works?
Darek
I see no issue with that...
Pretty straight forward. Activate one of the filters by clicking on it. Click near a type of the chosen filter and it is selected. when done selecting, click the icon with the checkmark to turn off filtering.
OK. I installed manually the Assembly 4 workbench because while I was trying to install it via addon manager it hangs, I don't know why.
But I got it to work and the Assembly 4 selection filters works as the selection filters at other CAD programs, I guess. It prevents from other type selection. So, if you select edge or face the vertex will not be selected. You need to hit the vertex directly to be selected. So this is little different from Woodworking version.
I am not sure what should be correct behavior in this case because normally there is problem with FreeCAD vertex hit. But looks like all CAD programs filter the selection instead of helping select nearest sub-object?
Darek
Re: [solved] FreeCAD has selection filters?
You can increase the vertex size and the hit radius in Preferences.
Yes, I created showVertex feature that makes all vertices bigger and red. But I found in practice that very often the Vertex, even bigger is not selected in the easy way. So this is why I created next feature selectVertex that help to select nearest Vertex even if you not hit the Vertex directly. In practice this works much better that making Vertex bigger. But if someone feel more comfort to make Vertex bigger, he can do it as well.
Also the selectVertex is better than showVertex because in practice there are situations the vertex touch the face, so you are not able to hit it directly, also you can't hide the other panel because you want to select vertex at it later.
EDIT: For example this situation at gif:
Darek
Actually, I offer a bounty for someone willing to implement those selection filters from the Assembly 4 wb in FreeCAD: viewtopic.php?t=72925
