Path to FeaturePython with PropertyFile
keithsloan52
Post by keithsloan52 »
If I have created a FeaturePython with a Property of "App::PropertyFile" how do I obtain the Path to the file?
I assume it is one of the main FreeCAD calls.
Re: Path to FeaturePython with PropertyFile
keithsloan52 wrote: Sat Feb 04, 2023 12:24 am If I have created a FeaturePython with a Property of "App::PropertyFile" how do I obtain the Path to the file?
It is not available as a property of DocumentObject?
keithsloan52
Well it has created one, I assume it creates a file in the same directory that will be used when the freecad file is saved as a zip Fc? No?
keithsloan52
Looking at property App::PropertyFileInclude https://wiki.freecad.org/FeaturePython_ ... leIncluded
I think it might be getDocTransientPath().
I will try when I get back to hotel this evening.
keithsloan52 wrote: Sat Feb 04, 2023 8:31 am Well it has created one, I assume it creates a file in the same directory that will be used when the freecad file is saved as a zip Fc? No?
From what I know, it usually reuse the last path, or probably the Home dir of the user, if you don't specify one, there is also a preference in Preferences, reachable with
print(FreeCAD.ParamGet("User parameter:BaseApp/Preferences/General").GetString('FileOpenSavePath'))
and writable with:
FreeCAD.ParamGet("User parameter:BaseApp/Preferences/General").SetString('FileOpenSavePath',   "<Your Desired Path>")
Hope it helps
keithsloan52 wrote: Sat Feb 04, 2023 8:44 am Looking at property App::PropertyFileInclude https://wiki.freecad.org/FeaturePython_ ... leIncluded
DOC.getPropertyByName('FileName')
return the full path of the file name.
DOC.getPropertyByName('TransientDir')
Will return instead the temp directory in the user directory (in my installation of 0.20.2 on Linux)
But I have tested them only on "standard objects" and not FeaturePython Objects.
Hope it helps.
Roy_043
Post by Roy_043 »
App::PropertyFile and App::PropertyFileIncluded are quite different. You should not mix them up. Which are we talking about?
keithsloan52
Roy_043 wrote: Sat Feb 04, 2023 11:43 am App::PropertyFile and App::PropertyFileIncluded are quite different. You should not mix them up. Which are we talking about?
I know that, but the FileIncluded Doc mentioned getDocTransientPath() App::PropertyFile does not mention anything about where the file can be found.
I am trying to create a PythonFeature which has a property that has a File, that will get saved when the Object gets saved and I can add code to drive an external editor to edit the file.
York uses FileIncluded in the Arch workbench but think the usage is different
keithsloan52 wrote: Sat Feb 04, 2023 5:28 pm
This will save a Txt file that I use as example to add "documentation" to a FCStd file, it is visible in when you open a FCStd document.
info_txt = '''
Text file with new lines that
is saved in the final FCStd doc.
txt_doc = out_doc.addObject("App::TextDocument","Text document")
txt_doc.Label = "Documentation"
txt_doc.Text = info_txt
But there is a way to add other things, let me see if I find
viewtopic.php?t=38201
and
Embedding other files
in: https://wiki.freecad.org/File_Format_FCStd
Hope it helps.
keithsloan52
Well if I use App::PropertyFile then I can achieve the desired functionality between the new OpenSCAD objects and an external editor (Emacs)
but the file is not saved with the FreeCAD file.
If I try App::PropertyFileIncluded then the file does not stay around long enough for me to use with an external editor.
A prototype replacement for the OpenSCAD work bench is at https://www.dropbox.com/scl/fo/m00vb2be ... 6o4gblubpo
The relevant source is OpenSCADFeatures.py class definition class SCADObject
External editor is hard coded EMACs on MacOS
Communication with Emacs uses pipes.
