I am testing 0.20.2 and latest weekly here. I have named constraints in my test Sketch and trying to solve pythagoras here (probably I could do this without expressions as well but do not know how).
When I give formula "Sketch003.Constraints.bottom_big_radius", the constraints is used (Picture 1). When I use Sketch003.Constraints.bottom_big_radius*Sketch003.Constraints.bottom_big_radius or pow(Sketch003.Constraints.bottom_big_radius,2) (Picture 2 and 3), I get message: "Unit mismatch between result and required unit". How could I prevent this happening?
Thanks a lot for help!
Picture 1:
Picture 2:
Picture 3:
How to multiply/pow constraints in formulas ?
Re: How to multiply/pow constraints in formulas ?
If you multiply two lengths together the result has units mm^2 To correct this divide the result by 1 mm.
Ah excellent. Great thanks! I just should have written the whole equation with sqrt included and the units would be correct after that.
Thanks very much for the answer!
- Capture d’écran 2023-02-01 213510.jpg (48.42 KiB) Viewed 520 times
Please also read Expressions.
