Link Branch - Pie Menu issue
lebearnais
Post by lebearnais »
Hi everyone,
I am on realthunder branch.
I have an issue with PIE menu.
I am on macos Catalina 10,15,7
I create a custom toolbar which I want to call by pressing a key. When I assign a letter, I can call the customized toolbar.
When I assign one of the F keys (F16,F17...) I have nothing. The customized toolbar does not appear.
The tab key can call pie menu.
Thanks for your help
Re: Link Branch - Pie Menu issue
Mod edit: please keep all posts regarding Link branch to this subforum. Please don't necrobump old posts (especially with Link branch related issues that are actually off-topic). Instead, start a new thread and reference the old thread.
Kunda1 wrote: Mon May 09, 2022 6:18 pm especially with Link branch related issues that are actually off-topic
I don't think it was off topic if that thread was about the development of this feature
It's confusing because pie-menu is also forked by realthunder, as you know, which also has a different keyboard shortcut scheme and other tweaks. This then can 'pollute' other threads that are not LS3 related.
Mpa
Post by Mpa »
lebearnais wrote: Mon May 09, 2022 5:20 pm Hi everyone,
I am using latest Branch and Fkeys are working Just fine.
I have created a video on how to make custom shortcuts please check them out Just to be sure you are doing things correct.
https://youtu.be/L_QQrg3A6q4
lebearnais
Thanks a lot for your answer.
Everything is working exept when you use function keys.... F1 F2 F3 ..... and that is my problem.
I have a streamdeck and I wanted to use F11, F12.... virtual keys to access to pi menu.
LordMadJack
Post by LordMadJack »
Just in case... Do you use F1 F2 F3 or Fn+F1, Fn+F2, Fn+F3
