(WORKAROUND) Zoom to fit freeze 3d window?
Re: (WORKAROUND) Zoom to fit freeze 3d window?
When you use Std_ViewFitAll on an empty model the problem does not occur. A similar solution could be implemented for Std_ViewFitSelection when a point is selected.
- thomas-neemann
Roy_043 wrote: ↑Mon May 23, 2022 5:18 pm ... A similar solution could be implemented for Std_ViewFitSelection when a point is selected.
unfortunately that doesn't work for me either. it is not a problem for me. I am currently developing a freecad training course. I run into this problem when doing an exercise. i will use 0.19.3 for this exercise and it will work around the problem
My workflow is not mainstream, it is optimized for speed and stability.That doesn't mean that the mainstream workflow is bad
My previous post was a suggestion for Yorik.
Hmm yes... setting a minimum distance maybe, that might be a good idea indeed
- thomas-neemann
the error is still there for me
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.21.31058 (Git) AppImage
Hash: e6c53d8642af36ce7d738ab6058b063ec58e0859
I was able to reproduce the problem and saved the file at that state.
Unpacked the file and checked the camera settings at the very end of GuiDocument.xml
<Camera settings="OrthographicCamera { viewportMapping ADJUST_CAMERA position -nan -nan -nan orientation 0 0 1 0 nearDistance 0 farDistance 0 aspectRatio 1 focalDistance 0 height 0 } "/>
- position is normally three floating point values (x,y,z) but -nan doesn't make any sense to me. Could also not find anything in the Coin-docs
- nearDistance clipping plane as well as farDistance clipping plane are set to 0. That means there is in fact no visible range for the camera
cheers
- thomas-neemann
thanks for the cooperation. Unfortunately I can't find any file
see wikipage File Format FCStdthomas-neemann wrote: ↑Thu Nov 24, 2022 8:02 amthanks for the cooperation. Unfortunately I can't find any file
cheers
