Here are my steps to reproduce...
Steps to Reproduce
- Using either the Part of Part Design Workbench
- Create a new body
- Select the body and update an attribute, eg: angle, axis x, y or z, position x, y, or z, etc
After selecting and updating an attribute, you should be able to select and update another attribute before forcing a recalculate.
Actual Result
While updating an attribute, sometimes the editor does not allow me to finish typing the new value, but updates with a partial value, especially when typing fast. More generally though, once an attribute has been updated, you have to select away from the current object, then reselect it to update another (or the same) attribute.
Other Actions
Have tried the following
- Typing slowly seems to allow you to enter the entire value before the editor auto-accepts it.
- Pressing F5 to recalculate - no difference
- Switching to other work benches - no difference
- Using the default / no workbench - no difference
- Reselecting the same object without unselecting it, or selecting another - no difference
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
* Curves 0.4.3
* fasteners 0.3.38
* fcgear
* parts_library
