[Solved] Sometimes snap doesn't work straight away
thomas-neemann
Post by thomas-neemann »
sometimes snap doesn't work straight away, I was able to reproduce it today. here is an example.
1021.FCStd
(6.47 KiB) Downloaded 37 times
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.26375 (Git) AppImage
Branch: (HEAD detached at 8a6e3d1)
Hash: 8a6e3d1b766a34546806b22d750929c2d00e30a6
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
https://www.youtube.com/watch?v=SqLxPrHibCI
phpBB [video]
Last edited by thomas-neemann on Thu Nov 25, 2021 4:28 pm, edited 3 times in total.
Roy_043
Re: Sometimes snap doesn't work straight away
Post by Roy_043 »
Draft_Snap_Parallel has this issue:
https://forum.freecadweb.org/viewtopic.php?f=23&t=60683
It occurs when you are moving the pointer around inside the smaller circle while drawing the 2nd line.
But there also may be an issue because the pointer is moved across the 2 circular edges.
Draft_Snap_WorkingPlane projects the snap point from another snap option onto the working plane. This snap option does not seem relevant here.
thomas-neemann
Roy_043 wrote: Thu Nov 18, 2021 10:28 am
I found a workaround
https://www.youtube.com/watch?v=sMgRSMXagw4
phpBB [video]
Roy_043
Re: [Workaround] Sometimes snap doesn't work straight away
Post by Roy_043 »
What also seems to work is move the pointer from one endpoint of the 1st line to the other.
thomas-neemann
Roy_043 wrote: Thu Nov 18, 2021 10:58 am What also seems to work is move the pointer from one endpoint of the 1st line to the other.
yes, wonderful, that is faster
Roy_043
Post by Roy_043 »
Here is an updated version of gui_snapper.py. It should be placed in <install_folder>/Mod/Draft/draftguitools/.
The 3 problems demonstrated here should be solved:
  1. Draft_Snap_Parallel only worked beyond the endpoints of the edge: https://forum.freecadweb.org/viewtopic.php?f=23&t=60683.
  2. It was very hard to select an edge for Draft_Snap_Parallel if no other snaps were active. This problem probably (?) was never detected because it does not occur if f.e. Draft_Snap_End is active.
  3. Only two snap objects were stored. Moving the cursor across two circular edges after selecting the reference for Draft_Snap_Parallel resulted in the loss of that reference. The number of stored objects was increased to 8. That number may prove to be too big. To avoid confusion the list is now emptied when a command finishes.
The file also contains this fix:
https://forum.freecadweb.org/viewtopic.php?f=23&t=60749
gui_snapper.zip
(14.77 KiB) Downloaded 26 times
thomas-neemann
Roy_043 wrote: Thu Nov 18, 2021 10:04 pm
yes it is better that way, for me it is so that I first have to move the mouse over the line to which something should be parallel
Roy_043
Post by Roy_043 »
thomas-neemann wrote: Fri Nov 19, 2021 7:38 am I first have to move the mouse over the line to which something should be parallel
Maybe I misunderstand, but yes you do have to do that. Imagine a document with many randomly oriented straight edges, how do you propose Draft_Snap_Parallel should work then?
thomas-neemann
Roy_043 wrote: Fri Nov 19, 2021 1:38 pm
yes, i had asked myself that if there are several similar oblique lines which are then used. Marvelous. freecad is now finished :-)
