funerary chapel
funerary chapel
Hello!
I wanted to share some images of a project that took quite long to develop, actually the last 3 years. FC was used to verify the construction drawings of the precast concrete builders, and to be able to visualize the step files coming from the sheet metal workshop.
The concrete model was built using Draft and Part WBs, while the Sheet Metal panels were drawn in 2d with Draft, sent to the workshop and imported through step. (We could also have designed them in SheetMetal, but you know, if someone else can do it better than you... )
Here is a small axonometric drawing obtained with TechDraw and a little bit of inkscape.
The model is quite dirty and not complete, cause it was mainly designed in 2d, and the drawings were continuously modified along the experimentations and construction, to check and verify the architectural choices.
you can checkout the result here: https://www.designboom.com/architecture ... 0-11-2021/
follow my experiments on BIM modelling for architecture design
Re: funerary chapel
Thanks! Looks really gorgeous !
Re: funerary chapel
BTW, what is the metal material ?
Re: funerary chapel
thanks!
anodized aluminum, chemically engraved by hand
Re: funerary chapel
Anywhere to learn how to write the specification ?
Or it is kind of personal art and craft skill ?
Thanks again
Thanks again
Re: funerary chapel
100% art and craft. it was done by an artist.
- ragohix769
Re: funerary chapel
Just Amazing!
It reminds me Tadao Ando
After #ElonMuskBuyTwitter I'm no more on Twitter, that's really enough
=> Now you can find me here on #Mastodon: https://mastodon.uno/@opensoul - I hope more people do the same
Re: funerary chapel
Looks great. You should post a picture.of the real thing directly here in the thread. You've to see it in real life.
Regards / Viele Grüße
Max
Max
