[BUG] Line.intersect / intersectCC between colinear line -> Segmentation fault
Cyril
Post by Cyril »
I found an issue using Line.intersect / intersectCC. Same for LineSegment.
  • Steps to reproduce :
    1. Open FreeCAD
    2. Run following code in python console :
    import Part
    doc = FreeCAD.newDocument()
    v = FreeCAD.Vector
    w1 = Part.makePolygon([v(0,0,0), v(0,10,0), v(-5, 5, 0), v(0,0,0)])
    w2 = Part.makePolygon([v(0,2,0), v(0,8,0), v(5, 5, 0), v(0,2,0)])
    Part.show(w1)
    Part.show(w2)
    e1 = w1.Edges[0]
    e2 = w2.Edges[0]
    e1.Curve.intersectCC(e2.Curve)
  • Log : see attachment
  • Error message :
    #0  /usr/lib/libc.so.6(+0x3bfb0) [0x7f1718865fb0]
    #1  0x7f168e3003a4 in Extrema_ExtCC::Points(int, Extrema_POnCurv&, Extrema_POnCurv&) const from /usr/lib/libTKGeomBase.so.7+0x54
    #2  0x7f168eae20d7 in GeomAPI_ExtremaCurveCurve::Points(int, gp_Pnt&, gp_Pnt&) const from /usr/lib/libTKGeomAlgo.so.7+0x57
    #3  0x7f1690dbe550 in Part::GeomCurve::intersect(opencascade::handle<Geom_Curve>, opencascade::handle<Geom_Curve>, std::vector<std::pair<Base::Vector3<double>, Base::Vector3<double> >, std::allocator<std::pair<Base::Vector3<double>, Base::Vector3<double> > > >&, double) from /usr/lib/freecad/lib/Part.so+0x3e0
    #4  0x7f1690dbeb2e in Part::GeomCurve::intersect(Part::GeomCurve*, std::vector<std::pair<Base::Vector3<double>, Base::Vector3<double> >, std::allocator<std::pair<Base::Vector3<double>, Base::Vector3<double> > > >&, double) const from /usr/lib/freecad/lib/Part.so+0xfe
    #5  0x7f1690cacfbe in Part::GeometryCurvePy::intersectCC(_object*) from /usr/lib/freecad/lib/Part.so+0x9e
    #6  0x7f1690cad1af in Part::GeometryCurvePy::staticCallback_intersectCC(_object*, _object*) from /usr/lib/freecad/lib/Part.so+0x1f
    #7  /usr/lib/libpython3.8.so.1.0(PyCFunction_Call+0xf3) [0x7f1719ffa5d3]
    #8  /usr/lib/libpython3.8.so.1.0(_PyObject_MakeTpCall+0x230) [0x7f1719fa3220]
    #9  /usr/lib/libpython3.8.so.1.0(_PyEval_EvalFrameDefault+0x4c9a) [0x7f171a00c97a]
    #10  /usr/lib/libpython3.8.so.1.0(_PyEval_EvalCodeWithName+0x2fa) [0x7f1719fd809a]
    #11  /usr/lib/libpython3.8.so.1.0(PyEval_EvalCodeEx+0x3a) [0x7f1719fd8cca]
    #12  /usr/lib/libpython3.8.so.1.0(PyEval_EvalCode+0x1c) [0x7f171a06473c]
    #13  0x7f171affbce6 in Gui::InteractiveInterpreter::runCode(PyCodeObject*) const from /usr/lib/freecad/lib/libFreeCADGui.so+0x66
    #14  0x7f171affc54c in Gui::InteractiveInterpreter::runSource(char const*) const from /usr/lib/freecad/lib/libFreeCADGui.so+0xac
    #15  0x7f171affc62d in Gui::InteractiveInterpreter::push(char const*) from /usr/lib/freecad/lib/libFreeCADGui.so+0xbd
    #16  0x7f171affc834 in Gui::PythonConsole::runSource(QString const&) from /usr/lib/freecad/lib/libFreeCADGui.so+0xf4
    #17  0x7f171affd107 in Gui::PythonConsole::runSourceFromMimeData(QString const&) from /usr/lib/freecad/lib/libFreeCADGui.so+0x737
    #18  0x7f171affeeac in Gui::PythonConsole::insertFromMimeData(QMimeData const*) from /usr/lib/freecad/lib/libFreeCADGui.so+0x1cc
    #19  /usr/lib/libQt5Widgets.so.5(+0x356664) [0x7f1719b2d664]
    #20  0x7f1719b32a13 in QWidgetTextControl::processEvent(QEvent*, QMatrix const&, QWidget*) from /usr/lib/libQt5Widgets.so.5+0x193
    #21  0x7f1719b28b1c in QWidgetTextControl::processEvent(QEvent*, QPointF const&, QWidget*) from /usr/lib/libQt5Widgets.so.5+0x5c
    #22  0x7f1719b03aa4 in QPlainTextEdit::keyPressEvent(QKeyEvent*) from /usr/lib/libQt5Widgets.so.5+0x254
    #23  0x7f171b029653 in Gui::TextEdit::keyPressEvent(QKeyEvent*) from /usr/lib/freecad/lib/libFreeCADGui.so+0x23
    #24  0x7f171affe097 in Gui::PythonConsole::keyPressEvent(QKeyEvent*) from /usr/lib/freecad/lib/libFreeCADGui.so+0x277
    #25  0x7f1719976e1b in QWidget::event(QEvent*) from /usr/lib/libQt5Widgets.so.5+0x88b
    #26  0x7f1719a2822f in QFrame::event(QEvent*) from /usr/lib/libQt5Widgets.so.5+0x1f
    #27  0x7f1719a2af7a in QAbstractScrollArea::event(QEvent*) from /usr/lib/libQt5Widgets.so.5+0x26a
    #28  0x7f1719b032b9 in QPlainTextEdit::event(QEvent*) from /usr/lib/libQt5Widgets.so.5+0xc9
    #29  0x7f1719932472 in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x82
    #30  0x7f171993c3c4 in QApplication::notify(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0xa74
    #31  0x7f171ae1f069 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib/freecad/lib/libFreeCADGui.so+0x89
    #32  0x7f1718e99832 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /usr/lib/libQt5Core.so.5+0x182
    #33  /usr/lib/libQt5Widgets.so.5(+0x1bdf3e) [0x7f1719994f3e]
    #34  0x7f1719932472 in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x82
    #35  0x7f171993bc89 in QApplication::notify(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x339
    #36  0x7f171ae1f069 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib/freecad/lib/libFreeCADGui.so+0x89
    #37  0x7f1718e99832 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /usr/lib/libQt5Core.so.5+0x182
    #38  0x7f171925e66d in QGuiApplicationPrivate::processKeyEvent(QWindowSystemInterfacePrivate::KeyEvent*) from /usr/lib/libQt5Gui.so.5+0x16d
    #39  0x7f17192639ba in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) from /usr/lib/libQt5Gui.so.5+0x26a
    #40  0x7f171923cc2c in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/libQt5Gui.so.5+0xbc
    #41  /usr/lib/libQt5XcbQpa.so.5(+0x66a2c) [0x7f17133aba2c]
    #42  /usr/lib/libglib-2.0.so.0(g_main_context_dispatch+0x27e) [0x7f17169d239e]
    #43  /usr/lib/libglib-2.0.so.0(+0x6c1b1) [0x7f17169d41b1]
    #44  /usr/lib/libglib-2.0.so.0(g_main_context_iteration+0x31) [0x7f17169d41f1]
    #45  0x7f1718ef1cc0 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/libQt5Core.so.5+0x60
    #46  0x7f1718e9839c in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/libQt5Core.so.5+0x12c
    #47  0x7f1718ea03a6 in QCoreApplication::exec() from /usr/lib/libQt5Core.so.5+0x96
    #48  0x7f171ad93222 in Gui::Application::runApplication() from /usr/lib/freecad/lib/libFreeCADGui.so+0x15e2
    #49  freecad(main+0x759) [0x5562249605d9]
    #50  /usr/lib/libc.so.6(__libc_start_main+0xf3) [0x7f1718851153]
    #51  freecad(_start+0x2e) [0x5562249608fe]
  • FreeCAD infos :
    OS: Manjaro Linux (GNOME/gnome)
    Version: 0.19 (Git)
    Hash: 49e4e45ff38b0459f0f9a76df634f6da4995b731
    Python version: 3.8.1
    Qt version: 5.14.0
    Locale: French/Switzerland (fr_CH)
FreeCAD.log
(17.85 KiB) Downloaded 74 times
I blog about HVAC / BIM / Energy : pythoncvc.net. If you like you can follow the RSS feed.
vocx
Re: [BUG] Line.intersect / intersectCC between colinear line -> Segmentation fault
Post by vocx »
Cyril wrote: Sat Jan 11, 2020 5:24 pm Hi,
This code does not produce a crash in my system.
>>> import Part
>>> # App.setActiveDocument("Unnamed")
>>> # App.ActiveDocument=App.getDocument("Unnamed")
>>> # Gui.ActiveDocument=Gui.getDocument("Unnamed")
>>> v = FreeCAD.Vector
>>> Part.show(w1)
>>> Part.show(w2)
>>> e1 = w1.Edges[0]
>>> e2 = w2.Edges[0]
[<Point (0,0,0) >]
OS: Ubuntu 18.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.19240 (Git)
Build type: Unknown
Hash: f97eb7026dfd59745829d4d8fb4831aa6354c099
Python version: 3.6.9
Qt version: 5.9.5
Your version is one commit older than my version.
You are trying to find the intersection of two co-linear edges (in the picture, it's where the two triangles meet). This would result in an infinite number of points; in my system it just returns the origin.
Always add the important information to your posts if you need help. Also see Tutorials and Video tutorials.
To support the documentation effort, and code development, your donation is appreciated: liberapay.com/FreeCAD.
Cyril
Post by Cyril »
vocx wrote: Sat Jan 11, 2020 10:14 pmYour version is one commit older than my version.
Thanks for testing. Yes, wmayer did commit while I was writing my bug report ^^ but Iooked at the last commit content and I am almost 100% sure that it is absolutely not related.
vocx wrote: Sat Jan 11, 2020 10:14 pmYou are trying to find the intersection of two co-linear edges (in the picture, it's where the two triangles meet). This would result in an infinite number of points; in my system it just returns the origin.
Yes I know. I was considering to use it in a loop handling the 3 cases. 1. I get an intersection. 2. I get no intersection. 3. I get (None or something like this) -> parallel or collinear. I am surprised that it returns Point(0,0,0) it might be confused with a real intersection at the origin. No ?
vocx wrote: Sat Jan 11, 2020 10:14 pm OCC version: 7.3.0
Maybe related to OCC 7.4 then ?
looo
Post by looo »
crashes with:
Version: 0.19.19242 (Git)
Hash: 2d752745c298108a1d7ec756bd0ca57818c7a174
Python version: 3.7.6
works with:
Version: 0.19.19066 (Git)
Hash: c766d757912ded11d41bc825f82c47a8428396ad
Seems like occt7.4 introduced a new bug. :evil:
Cyril
Post by Cyril »
looo wrote: Sun Jan 12, 2020 6:49 pm Seems like occt7.4 introduced a new bug. :evil:
Thanks for testing.
I opened an issue on bug tracker : https://www.freecadweb.org/tracker/view.php?id=4247
looo
Post by looo »
It would be interesting to see what the diff between occt7.4 and occt7.3 for the function: GeomAPI_ExtremaCurveCurve::Points(int, gp_Pnt&, gp_Pnt&) looks like. There are several regression commits for occt but I didn't see one which is related to the problem reported here.
looo wrote: Mon Jan 13, 2020 2:46 pm It would be interesting to see what the diff between occt7.4 and occt7.3 for the function: GeomAPI_ExtremaCurveCurve::Points(int, gp_Pnt&, gp_Pnt&) looks like. There are several regression commits for occt but I didn't see one which is related to the problem reported here.
Shouldn't this be possible using git blame ?
looo
Post by looo »
Kunda1 wrote: Mon Jan 13, 2020 3:01 pm Shouldn't this be possible using git blame ?
My problem is that I have no accesss to the git repo of opencascade.
ickby
Post by ickby »
As it is a regression one could also report it on the occ bug tracker, usually those regressions are fixed by them.
ickby wrote: As it is a regression one could also report it on the occ bug tracker, usually those regressions are fixed by them.
gAdlike wrote: pinged by pinger macro
kkremitzki wrote: pinged by pinger macro
Quaoar wrote: pinged by pinger macro
Hi, is one of you available to make an upstream ticket ?
