FreeCAD natively under Gnome/Wayland
This subforum is specifically to discuss packaging issues on different platforms (windows, mac, linux), and using different packaging systems (conda, etc...)
tsadowski
Post by tsadowski »
with Qt 5.12 it is possible to run FreeCAD natively under Wayland. All window decorations are nicely drawn. It is also crisper on HiDPI displays because scaling is handled better. I had to hack the Coin3d build to prevent the linking with libglx, because otherwise FreeCAD would crash as soon as a new document is created or opened.
Cheers, Torsten
NormandC
Re: FreeCAD natively under Gnome/Wayland
Post by NormandC »
Thank you for your report, Torsten. I had been wondering about it, since Linux distros are gradually phasing out the old X server.
yorik
Post by yorik »
Very nice!! Haven't tried wayland yet, but it's impressive to see that a complex 3D app with lots of (some old) dependencies like freecad works...
@tsadowski can you show the code that you hacked to make this happen ?
tsadowski
Post by tsadowski »
It was quite easy. Coin works without glx for FreeCAD probably because the funtionality is not needed by FreeCAD and Coin has a dummy implementation. I just had to add a patch to the Arch build recipy:
https://aur.archlinux.org/packages/coin-hg/
not to find glx:
diff -ura coin/CMakeLists.txt coin.new/CMakeLists.txt
--- coin/CMakeLists.txt 2019-01-10 00:06:52.081521372 +0100
+++ coin.new/CMakeLists.txt     2019-01-10 00:08:32.785648305 +0100
@@ -431,7 +431,7 @@
   check_include_files("GL/gl.h" HAVE_GL_GL_H)
   check_include_files("GL/glu.h" HAVE_GL_GLU_H)
   check_include_files("GL/gl.h;GL/glext.h" HAVE_GL_GLEXT_H)
-  check_include_files("GL/glx.h" HAVE_GLX_H)
+#  check_include_files("GL/glx.h" HAVE_GLX_H)
 endif()
 check_include_file(OpenGL/gl.h HAVE_OPENGL_GL_H)
@@ -459,9 +459,9 @@
 check_symbol_exists(CGL_VERSION_1_0 OpenGL/OpenGL.h HAVE_CGL)
 set(HAVE_CGL_PBUFFER ${HAVE_CGL})
-if(NOT (HAVE_WGL OR HAVE_AGL OR HAVE_CGL))
-  check_library_exists(GL glXChooseVisual "" HAVE_GLX)
-endif()
+#if(NOT (HAVE_WGL OR HAVE_AGL OR HAVE_CGL))
+#  check_library_exists(GL glXChooseVisual "" HAVE_GLX)
+#endif()
 if(HAVE_WINDOWS_H)
   set(SIM_INCLUDE_WINDOWS_H "#include <windows.h>")
I tried to add some runtime workarounds in FreeCAD but this is awkward and probably doomed. Coin probably needs to use EGL instead of GLX. I will check if there is an easy solution and contact the Coin team.
Cheers,
Torsten
triplus
Post by triplus »
tsadowski wrote: Fri Jan 11, 2019 10:43 pm I will check if there is an easy solution and contact the Coin team.
Cheers,
Torsten
That would be great. Likely still a few years before Wayland becomes more widely used and majority of applications add support. But FreeCAD providing support should happen sooner rather than later. If possible. Therefore Coin3D needs to get adapted and as for the Qt. You likely had to use QtWayland module in the procedure somehow? Can Wayland/X11 option be set with an environment variable before starting FreeCAD?
hobbes1069
Post by hobbes1069 »
tsadowski wrote: Fri Jan 11, 2019 10:43 pm I tried to add some runtime workarounds in FreeCAD but this is awkward and probably doomed. Coin probably needs to use EGL instead of GLX. I will check if there is an easy solution and contact the Coin team.
Any luck with the Coin team with EGL support?
Thanks,
Richard
hobbes1069
For posterity with the current 4.0.0 release I had to update the patch to the following:
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -586,11 +586,11 @@ if(NOT (HAVE_WGL OR HAVE_AGL OR HAVE_CGL
     list(APPEND COIN_TARGET_LINK_LIBRARIES OpenGL::GLX)
   endif()
   set(CMAKE_REQUIRED_LIBRARIES ${COIN_TARGET_LINK_LIBRARIES})
-  check_cxx_source_compiles("
-    #include <GL/gl.h>
-    #include <GL/glx.h>
-    int main() { (void)glXChooseVisual(0L, 0, 0L); glEnd(); return 0; }
-  " HAVE_GLX)
+#  check_cxx_source_compiles("
+#    #include <GL/gl.h>
+#    #include <GL/glx.h>
+#    int main() { (void)glXChooseVisual(0L, 0, 0L); glEnd(); return 0; }
+#  " HAVE_GLX)
 endif()
 # Checks specific OpenGL configurations
Thanks,
Richard
ElliotLee
Post by ElliotLee »
I don't see any issues open in the Coin issue tracker on this topic - https://bitbucket.org/Coin3D/coin/issue ... tatus=open
Would someone (with a better grasp of the topic than I) file one?
kkremitzki
Post by kkremitzki »
BTW, a move to github.com/coin3d is underway.
Like my FreeCAD work? I'd appreciate any level of support via Patreon, Liberapay, or PayPal! Read more about what I do at my blog.
