call for screenshots - By Yorik
Forthman
Re: call for screenshots - By Yorik
Post by Forthman »
My big current project
(I don't give too much information coz it is a professional project )
Capture d’écran_2019-04-02_15-38-05.png (221.49 KiB) Viewed 11252 times
Capture d’écran_2019-04-02_15-40-59.png (242.07 KiB) Viewed 11252 times
Capture d’écran_2019-04-02_15-49-46.png (113.98 KiB) Viewed 11252 times
Capture d’écran_2019-04-02_15-44-26.png (248.13 KiB) Viewed 11252 times
Capture d’écran_2019-04-02_15-45-41.png (114.04 KiB) Viewed 11252 times
schupin
Post by schupin »
Very nice !
Do you plane to animate all this ?
Forthman
Post by Forthman »
in real life only :P
this project should see the day in August (hopefully) :roll:
yorik
Post by yorik »
VERY impressive!
triplus
Post by triplus »
Looking Pro!
OficineRobotica wrote: Sat Mar 16, 2019 6:33 am @bitacovir
bitacovir wrote: Sat Mar 16, 2019 1:24 am How did you split the Tree view and the Property view in different panels?
The right side panel is just the combo view where i pulled up the "data view" widget to cover the tree. The left side view is the Glass addon (download with the addon manager) wich @triplus was kind enough to help me to modify. It's really easy tough. Once downloaded the addon go to your .FreeCAD/Mod/Glass/ folder then replace the line 35 of GlassGui.py with:
dock = mw.findChild(QtGui.QDockWidget, "Tree view")
On line 77 chose a "color"(of the text) that suits your 3d view background preference .
widget.setStyleSheet(" background:transparent; border:none; color:white;")
It is incredible how a small change can inhance the workflow especially when working with multi body files. It gets dificult for me to get back to the clasic interface after using this kind of arrangement.
It works with the py3/qt5 appimage version. There is some discusion here: https://forum.freecadweb.org/viewtopic.php?f=34&t=32397
Thank you sir for pointing me out to this! It really is a great improvement.
arturromarr
Post by arturromarr »
It's good to see the FC program in real projects.
4Yub1
Post by 4Yub1 »
Hallo all... :)
Several days ago, i attending machinery training in my country, Bandung, West Java, Indonesia. This training provided by Indonesian Ministry Industry and Man Power. This free of charge and took short course on basic machining.
This what i learned so far, I share to you. :)
I copied a Model Compass from https://www.hahn-kolb.de germany but with different dimensions and modeled with FreeCAD 18.04-Daily.
4Yub1 wrote: Tue Jul 16, 2019 3:12 am Hallo all... :)
Hi and welcome to the forum!
Did they use FreeCAD in the course as well?
You can improve the presentation of your nice project if you show only the relevant parts of it, i.e. only the tree and 3D view and consider removing the grid as well.
Edit: Finally you should upload the image to the forum as it is not visible for us users.
4Yub1
Post by 4Yub1 »
chrisb wrote: Tue Jul 16, 2019 6:56 am
Nope, they teaching modeling using Autodesk Inventor.
Thanks for your advices.
Revision 1.0
Workspace 1_008.png (236.96 KiB) Viewed 9602 times
Workspace 1_009.png (209.72 KiB) Viewed 9602 times
Workspace 1_007.png (307.24 KiB) Viewed 9602 times
Ps : Sorry for my bad english, still improving & learning english grammar. :P
