[feature request] improvement of sketcher usebility
Jee-Bee
Post by Jee-Bee »
I have a feature request for sketcher.
Don't know if this are difficult features to implement. Both are related for usebility and fail proof of a sketch.
  1. mark closed sketches. for example Creo give it a color.
  2. Mark non closed endpoints. so every endpoint what is not attached another give it a marker.
I have no clue if it is difficult to add so i let this to somebody else...
see figure for examples
easyw-fc
Re: [feature request] improvement of sketcher usebility
Post by easyw-fc »
Jee-Bee wrote: Thu Apr 19, 2018 9:49 am I have a feature request for sketcher.
Validate Sketch can show missing coincidences
yorik
Post by yorik »
showing closed loops in another color is not a bad idea actually... I kind of like it
NormandC
Post by NormandC »
That's a cool idea. It may help with all the posts about "failed to validate broken face".
But ideally it should have an option in the Sketcher preferences to disable it.
Jee-Bee
Post by Jee-Bee »
NormandC wrote: Fri Apr 20, 2018 2:11 am It may help with all the posts about "failed to validate broken face".
I can now ask the same question based on a single try yesterday evening... it was grayed out :P
But I figure it out ;)
I think Abdullah should know about this. It might be possible to integrate it into the improvement on showing missing constraints.
abdullah wrote:abdullah
abdullah
Post by abdullah »
chrisb wrote: Fri Apr 20, 2018 6:31 am I think Abdullah should know about this. It might be possible to integrate it into the improvement on showing missing constraints.
Of course, that is possible. My doubts when implementing those are always in the line: "should it be automatic or on request?", the rationale being whether we should "overload" the system on every solve() or not.
I can certainly give it a go (you may file a feature request to my name).
In any case, before going on improving the sketcher feedback, I think this PR should be merged:
https://github.com/FreeCAD/FreeCAD/pull/1345
and we should mix the feedback on that PR with what is discussed here. ;)
easyw-fc
Post by easyw-fc »
It would possible, if there are not already, to expose also 'not coincident points' and 'fix sketch' to python?
abdullah wrote: Sat Apr 21, 2018 9:29 am Of course, that is possible. My doubts when implementing those are always in the line: "should it be automatic or on request?", the rationale being whether we should "overload" the system on every solve() or not.
There is a third variant, which I would favor: Have a checkbox which can be preset by a preference or by its last state, albeit the last state in the session.
Created issue: issue #3438.
Jee-Bee
Post by Jee-Bee »
From user perspective automatically. In Creo there is a button in the toolbar what is switched when it is on. what's kind of in between.
As long as it is not like the 'validate sketch' where you have to go out the sketch to check if it can be solved. I need it while i'm sketching ...
