I have created my own python feature (code and macro to execute below) to create a very simple 4 sided cabinet. I want to use Part > Attachment to control its placement parametrically linked to other objects. I see in this thread https://forum.freecadweb.org/viewtopic.php?f=10&t=18978 that there is Part::AttachExtension. Can I add this to my code somehow to do this?
At the moment I can workaround this by cloning the object, as clones are parametrically attachable.
Ben
Carcass.py
class CarcassShape:
def __init__(self,obj):
obj.Proxy = self
obj.addProperty("App::PropertyFloat","thickness")
obj.addProperty("App::PropertyFloat","width")
obj.addProperty("App::PropertyFloat","height")
obj.addProperty("App::PropertyFloat","depth")
def execute(self,obj):
# we need to import the FreeCAD module here too, because we might be running out of the Console
# (in a macro, for example) where the FreeCAD module has not been imported automatically
import Part,FreeCAD
# first we need to make sure the values of properties are not 0
# otherwise the Part.Line will complain that both points are equal
if (obj.thickness == 0) or (obj.width == 0) or (obj.height == 0) or (obj.depth == 0):
# if yes, exit this method without doing anything
return
#make the vertices
v1 = FreeCAD.Vector(0,0,0)
v2 = FreeCAD.Vector(0,obj.depth,0)
v3 = FreeCAD.Vector(obj.thickness,obj.depth,0)
v4 = FreeCAD.Vector(obj.thickness,0,0)
v5 = FreeCAD.Vector(0,0,obj.height)
v6 = FreeCAD.Vector(0,obj.depth,obj.height)
v7 = FreeCAD.Vector(obj.thickness,obj.depth,obj.height)
v8 = FreeCAD.Vector(obj.thickness,0,obj.height)
v9 = FreeCAD.Vector(obj.width-obj.thickness,0,0)
v10 = FreeCAD.Vector(obj.width-obj.thickness,obj.depth,0)
v11 = FreeCAD.Vector(obj.width,obj.depth,0)
v12 = FreeCAD.Vector(obj.width,0,0)
v13 = FreeCAD.Vector(obj.width-obj.thickness,0,obj.height)
v14 = FreeCAD.Vector(obj.width-obj.thickness,obj.depth,obj.height)
v15 = FreeCAD.Vector(obj.width,obj.depth,obj.height)
v16 = FreeCAD.Vector(obj.width,0,obj.height)
v17 = FreeCAD.Vector(obj.thickness,obj.depth,obj.thickness)
v18 = FreeCAD.Vector(obj.thickness,0,obj.thickness)
v19 = FreeCAD.Vector(obj.width-obj.thickness,0,obj.thickness)
v20 = FreeCAD.Vector(obj.width-obj.thickness,obj.depth,obj.thickness)
v21 = FreeCAD.Vector(obj.thickness,obj.depth,obj.height-obj.thickness)
v22 = FreeCAD.Vector(obj.thickness,0,obj.height-obj.thickness)
v23 = FreeCAD.Vector(obj.width-obj.thickness,0,obj.height-obj.thickness)
v24 = FreeCAD.Vector(obj.width-obj.thickness,obj.depth,obj.height-obj.thickness)
# Make the edges
w1 = Part.makePolygon([v1,v2,v3,v4,v1])
w2 = Part.makePolygon([v1,v5,v6,v2,v1])
w3 = Part.makePolygon([v4,v8,v7,v3,v4])
w4 = Part.makePolygon([v1,v5,v8,v4,v1])
w5 = Part.makePolygon([v2,v6,v7,v3,v2])
w6 = Part.makePolygon([v5,v6,v7,v8,v5])
w7 = Part.makePolygon([v9,v10,v11,v12,v9])
w8 = Part.makePolygon([v13,v14,v15,v16,v13])
w9 = Part.makePolygon([v9,v13,v14,v10,v9])
w10 = Part.makePolygon([v10,v14,v15,v11,v10])
w11 = Part.makePolygon([v12,v16,v15,v11,v12])
w12 = Part.makePolygon([v9,v13,v16,v12,v9])
w13 = Part.makePolygon([v3,v4,v9,v10,v3])
w14 = Part.makePolygon([v17,v18,v19,v20,v17])
w15 = Part.makePolygon([v4,v18,v17,v3,v4])
w16 = Part.makePolygon([v3,v17,v20,v10,v3])
w17 = Part.makePolygon([v10,v20,v19,v9,v10])
w18 = Part.makePolygon([v4,v18,v19,v9,v4])
w19 = Part.makePolygon([v21,v22,v23,v24,v21])
w20 = Part.makePolygon([v7,v8,v13,v14,v7])
w21 = Part.makePolygon([v22,v8,v7,v21,v22])
w22 = Part.makePolygon([v21,v7,v14,v24,v21])
w23 = Part.makePolygon([v14,v24,v23,v13,v14])
w24 = Part.makePolygon([v23,v13,v8,v22,v23])
#make the faces
f1 = Part.Face(w1)
f2 = Part.Face(w2)
f3 = Part.Face(w3)
f4 = Part.Face(w4)
f5 = Part.Face(w5)
f6 = Part.Face(w6)
f7 = Part.Face(w7)
f8 = Part.Face(w8)
f9 = Part.Face(w9)
f10 = Part.Face(w10)
f11 = Part.Face(w11)
f12 = Part.Face(w12)
f13 = Part.Face(w13)
f14 = Part.Face(w14)
f15 = Part.Face(w15)
f16 = Part.Face(w16)
f17 = Part.Face(w17)
f18 = Part.Face(w18)
f19 = Part.Face(w19)
f20 = Part.Face(w20)
f21 = Part.Face(w21)
f22 = Part.Face(w22)
f23 = Part.Face(w23)
f24 = Part.Face(w24)
#make the shells
shell1=Part.makeShell([f1,f2,f3,f4,f5,f6])
shell2=Part.makeShell([f7,f8,f9,f10,f11,f12])
shell3=Part.makeShell([f13,f14,f15,f16,f17,f18])
shell4=Part.makeShell([f19,f20,f21,f22,f23,f24])
#make the solids
leftcheek=Part.makeSolid(shell1)
rightcheek=Part.makeSolid(shell2)
base=Part.makeSolid(shell3)
top=Part.makeSolid(shell4)
#make compound from solids
comp1 = Part.makeCompound([leftcheek,rightcheek,base,top])
# All shapes have a Placement too. We give our shape the value of the placement
# set by the user. This will move/rotate the face automatically.
comp1.Placement = obj.Placement
# all done, we can attribute our shape to the object!
obj.Shape = comp1
import Carcass
myObj = FreeCAD.ActiveDocument.addObject("Part::FeaturePython","Carcass")
Carcass.CarcassShape(myObj)
myObj.ViewObject.Proxy = 0 # this is mandatory unless we code the ViewProvider too
FreeCAD.ActiveDocument.recompute()
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.17.12323 (Git)
Build type: None
Hash: 30379bc1ce309fcc1e0f780378babfd4104bee4c
Python version: 2.7.12
Qt version: 4.8.7
OCC version: 7.1.0
Locale: English/UnitedKingdom (en_GB)
