Small script for translator (for local work)
Kuzma30
Post by Kuzma30 »
As described in the wiki, there are scripts to work with translation files, upload them to the server, and update the translations in a branch. They work great, but there is one problem (for me). They need admin rights of the crowdin.com server to work.
As a small translator, I had a problem with the update of the translation in the freecad program. I like to see and edit translations as necessary, depending on how they look in the program itself. My language (Ukrainian) is context sensitive.
It's all lyrics. So I'll get down to business.
A script was written that updates the translation files in the program. The source file is the downloaded archive from the server. It's look like FreeCAD $Your_Language_CODE.zip
There are 3 variables in the script, 2 language codes, with capital and small letters, and the location of the directory with FreeCAD source. They can be changed according to your needs.
I am not a great programmer and not a great translator (I can write with errors in English), but the script seems to work. Use at your own risk.
# define language code here
lang_Code="uk"
lang_Code_Upper_Case="UK"
FreeCAD="FreeCAD"
#Make directory for extracted files
mkdir -p FreeCAD_$lang_Code_Upper_Case
#Unzip archive to directory
unzip "FreeCAD ($lang_Code).zip" -d FreeCAD_$lang_Code_Upper_Case
echo "Preparing files"
#rename all files in directory
cd FreeCAD_$lang_Code_Upper_Case
rename 's/.ts$//' *.ts
ls | xargs -I {} mv {} {}_$lang_Code.ts
rm homepage.po_$lang_Code.ts
echo "Start creating qm files"
#Create qm files for all ts
lrelease *.ts
#Update ts in FreeCAD tree
echo "Copying translation files in defined place"
cp AddonManager_$lang_Code.* ~/$FreeCAD/src/Mod/AddonManager/Resources/translations/
cp Arch_$lang_Code.* ~/$FreeCAD/src/Mod/Arch/Resources/translations
cp Assembly_$lang_Code.* ~/$FreeCAD/src/Mod/Assembly/Gui/Resources/translations
#Complete_$lang_Code.ts
#draft_$lang_Code.ts
cp Drawing_$lang_Code.* ~/$FreeCAD/src/Mod/Drawing/Gui/Resources/translations
cp Fem_$lang_Code.* ~/$FreeCAD/src/Mod/Fem/Gui/Resources/translations
cp FreeCAD_$lang_Code.* ~/$FreeCAD/src/Gui/Language
cp Image_$lang_Code.* ~/$FreeCAD/src/Mod/Image/Gui/Resources/translations
cp MeshPart_$lang_Code.* ~/$FreeCAD/src/Mod/MeshPart/Gui/Resources/translations
cp Mesh_$lang_Code.* ~/$FreeCAD/src/Mod/Mesh/Gui/Resources/translations
cp OpenSCAD_$lang_Code.* ~/$FreeCAD/src/Mod/OpenSCAD/Resources/translations
cp PartDesign_$lang_Code.* ~/$FreeCAD/src/Mod/PartDesign/Gui/Resources/translations
cp Part_$lang_Code.* ~/$FreeCAD/src/Mod/Part/Gui/Resources/translations
cp Path_$lang_Code.* ~/$FreeCAD/src/Mod/Path/Gui/Resources/translations
#Plot_$lang_Code.ts
cp Points_$lang_Code.* ~/$FreeCAD/src/Mod/Points/Gui/Resources/translations
cp Raytracing_$lang_Code.* ~/$FreeCAD/src/Mod/Raytracing/Gui/Resources/translations
cp ReverseEngineering_$lang_Code.* ~/$FreeCAD/src/Mod/ReverseEngineering/Gui/Resources/translations
cp Robot_$lang_Code.* ~/$FreeCAD/src/Mod/Robot/Gui/Resources/translations
#Ship_$lang_Code.ts
cp Sketcher_$lang_Code.* ~/$FreeCAD/src/Mod/Sketcher/Gui/Resources/translations
cp Spreadsheet_$lang_Code.* ~/$FreeCAD/src/Mod/Spreadsheet/Gui/Resources/translations
cp StartPage_$lang_Code.* ~/$FreeCAD/src/Mod/Start/Gui/Resources/translations
cp TechDraw_$lang_Code.ts ~/$FreeCAD/src/Mod/TechDraw/Gui/Resources/translations
cp Test_$lang_Code.ts ~/$FreeCAD/src/Mod/Test/Gui/Resources/translations
cp Tux_$lang_Code.ts ~/$FreeCAD/src/Mod/Tux/Resources/translations
cp Web_$lang_Code.ts ~/$FreeCAD/src/Mod/Web/Gui/Resources/translations
echo "Finish. Now you may re-build FreeCAD to see updated translation for $lang_Code_Upper_Case language"
To rerun script you need empty temporary directory FreeCAD_$lang_Code_Upper_Case. I don't found where Complete.ts, draft.ts, Ship.ts Plot.ts is placed and ignore it.
Знімок екрана з 2022-04-16 19-32-09.png (65.79 KiB) Viewed 2282 times
RealThunder's A3 Wiki translation, join the project https://crowdin.com/project/freecad-asm3-wiki
Re: Small script for translator (for local work)
Great stuff. Can you open an issue and mention this script on https://github.com/FreeCAD/FreeCAD-translations/issues ?
Kuzma30
Post by Kuzma30 »
Kunda1 wrote: Sat Apr 16, 2022 5:42 pm Great stuff. Can you open an issue and mention this script on https://github.com/FreeCAD/FreeCAD-translations/issues ?
https://github.com/FreeCAD/FreeCAD-tran ... issues/110 Done.
kaktus
Post by kaktus »
:mrgreen:
I can congratulate you on the good work.
Today the FreeCAD-translations Testing section has been completed for translators testing in their environment.
There is a good dose of useful information there. ;)
Kuzma30
Post by Kuzma30 »
kaktus wrote: Sat Apr 16, 2022 7:01 pm :mrgreen:
Thanks.
Thoughts are material:) I honestly haven't seen your script implementation, it's more elegant.
kaktus
Post by kaktus »
:mrgreen:
Your skrpt overwrites the translation files supplied with your FreeCAD installation.
This is not a good solution, but it works. :roll:
FreeCAD has a place in its directory structure for alternative translation files. It is worth using it.
First-hand information.
https://forum.freecadweb.org/viewtopic. ... 64#p533464
You may possibly find the whole topic interesting. The link will take you directly to wmayer's developer post.
This also works for the operating system coming from Redmond. :lol:
The instructions on GitHub to which I posted a link earlier contain all this information.
My warmest regards to you :D
Kuzma30
Post by Kuzma30 »
Many copy/paste and I make another script (for separately downloaded files). It also rewrite ts files in FreeCAD source.
lang_Code="uk"
FreeCAD="FreeCAD"
case "$1" in
    "AddonManager.ts")
	echo " AddonManager.ts"
	lrelease  AddonManager.ts
	cp AddonManager.ts ~/$FreeCAD/src/Mod/AddonManager/Resources/translations/AddonManager_$lang_Code.ts
	cp AddonManager.qm ~/$FreeCAD/src/Mod/AddonManager/Resources/translations/AddonManager_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for AddonManager_$lang_Code_Upper_Case";;
    "Arch.ts")
	echo " Arch.ts"
	lrelease  Arch.ts
	cp Arch.ts ~/$FreeCAD/src/Mod/Arch/Resources/translations/Arch_$lang_Code.ts
	cp Arch.qm ~/$FreeCAD/src/Mod/Arch/Resources/translations/Arch_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for Arch_$lang_Code_Upper_Case";;
    "Assembly.ts")
	echo " Assembly.ts"
	lrelease  Assembly.ts
	cp Assembly.ts ~/$FreeCAD/src/Mod/Assembly/Gui/Resources/translations/Assembly_$lang_Code.ts
	cp Assembly.qm ~/$FreeCAD/src/Mod/Assembly/Gui/Resources/translations/Assembly_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for Assembly_$lang_Code_Upper_Case";;
    "Complete.ts")
	echo " Complete.ts"
	lrelease  Complete.ts
	cp Complete.ts Complete_$lang_Code.ts
	cp Complete.qm Complete_$lang_Code.qm
	echo "Unknow location for files. Place it yourself";;
    "draft.ts")
	echo "draft.ts"
	lrelease  draft.ts
	cp draft.ts ~/$FreeCAD/src/Mod/Draft/Resources/translations/Draft_$lang_Code.ts
	cp draft.qm ~/$FreeCAD/src/Mod/Draft/Resources/translations/Draft_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for Draft_$lang_Code_Upper_Case";;
    "Drawing.ts")
	echo "Drawing.ts"
	lrelease  Drawing.ts
	cp Drawing.ts ~/$FreeCAD/src/Mod/Drawing/Gui/Resources/translations/Drawing_$lang_Code.ts
	cp Drawing.qm ~/$FreeCAD/src/Mod/Drawing/Gui/Resources/translations/Drawing_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for Drawing_$lang_Code_Upper_Case";;
    "Fem.ts")
	echo "Fem.ts"
	lrelease  Fem.ts
	cp Fem.ts ~/$FreeCAD/src/Mod/Fem/Gui/Resources/translations/Fem_$lang_Code.ts
	cp Fem.qm ~/$FreeCAD/src/Mod/Fem/Gui/Resources/translations/Fem_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for Fem_$lang_Code_Upper_Case";;
    "FreeCAD.ts")
	echo "FreeCAD.ts"
	lrelease  FreeCAD.ts
	cp FreeCAD.ts ~/$FreeCAD/src/Gui/Language/FreeCAD_$lang_Code.ts
	cp FreeCAD.qm ~/$FreeCAD/src/Gui/Language/FreeCAD_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for FreeCAD_$lang_Code_Upper_Case";;
    "Image.ts")
	echo " Image.ts"
	lrelease  Image.ts
	cp Image.ts ~/$FreeCAD/src/Mod/Image/Gui/Resources/translations/Image_$lang_Code.ts
	cp Image.qm ~/$FreeCAD/src/Mod/Image/Gui/Resources/translations/Image_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for Image_$lang_Code_Upper_Case";;
    "MeshPart.ts")
	echo " MeshPart.ts"
	lrelease  MeshPart.ts
	cp MeshPart.ts ~/$FreeCAD/src/Mod/MeshPart/Gui/Resources/translations/MeshPart_$lang_Code.ts
	cp MeshPart.qm ~/$FreeCAD/src/Mod/MeshPart/Gui/Resources/translations/MeshPart_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for MeshPart_$lang_Code_Upper_Case";;
    "Mesh.ts")
	echo "Mesh.ts"
	lrelease  Mesh.ts
	cp Mesh.ts ~/$FreeCAD/src/Mod/Mesh/Gui/Resources/translations/Mesh_$lang_Code.ts
	cp Mesh.qm ~/$FreeCAD/src/Mod/Mesh/Gui/Resources/translations/Mesh_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for Mesh_$lang_Code_Upper_Case";;
    "OpenSCAD.ts")
	echo "OpenSCAD.ts"
	lrelease  OpenSCAD.ts
	cp OpenSCAD.ts ~/$FreeCAD/src/Mod/OpenSCAD/Resources/translations/OpenSCAD_$lang_Code.ts
	cp OpenSCAD.qm ~/$FreeCAD/src/Mod/OpenSCAD/Resources/translations/OpenSCAD_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for OpenSCAD_$lang_Code_Upper_Case";;
    "PartDesign.ts")
	echo " PartDesign.ts"
	lrelease  PartDesign.ts
	cp PartDesign.ts ~/$FreeCAD/src/Mod/PartDesign/Gui/Resources/translations/PartDesign_$lang_Code.ts
	cp PartDesign.qm ~/$FreeCAD/src/Mod/PartDesign/Gui/Resources/translations/PartDesign_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for PartDesign_$lang_Code_Upper_Case";;
    "Part.ts")
	echo "Part.ts"
	lrelease  Part.ts
	cp Part.ts ~/$FreeCAD/src/Mod/Part/Gui/Resources/translations/Part_$lang_Code.ts
	cp Part.qm ~/$FreeCAD/src/Mod/Part/Gui/Resources/translations/Part_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for Part_$lang_Code_Upper_Case";;
    "Path.ts")
	echo " Path.ts"
	lrelease  Path.ts
	cp Path.ts ~/$FreeCAD/src/Mod/Path/Gui/Resources/translations/Path_$lang_Code.ts
	cp Path.qm ~/$FreeCAD/src/Mod/Path/Gui/Resources/translations/Path_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for Path_$lang_Code_Upper_Case";;
    "Plot.ts")
	echo "Plot.ts"
	lrelease  Plot.ts
	cp Plot.ts Plot_$lang_Code.ts
	cp Plot.qm Plot_$lang_Code.qm
    "Points.ts")
	echo "Points.ts"
	lrelease  Points.ts
	cp Points.ts ~/$FreeCAD/src/Mod/Points/Gui/Resources/translations/Points_$lang_Code.ts
	cp Points.qm ~/$FreeCAD/src/Mod/Points/Gui/Resources/translations/Points_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for Points_$lang_Code_Upper_Case";;
    "Raytracing.ts")
	echo " Raytracing.ts"
	lrelease  Raytracing.ts
	cp Raytracing.ts ~/$FreeCAD/src/Mod/Raytracing/Gui/Resources/translations/Raytracing_$lang_Code.ts
	cp Raytracing.qm ~/$FreeCAD/src/Mod/Raytracing/Gui/Resources/translations/Raytracing_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for Raytracing_$lang_Code_Upper_Case";;
    "ReverseEngineering.ts")
	echo " ReverseEngineering.ts"
	lrelease  ReverseEngineering.ts
	cp ReverseEngineering.ts ~/$FreeCAD/src/Mod/ReverseEngineering/Gui/Resources/translations/ReverseEngineering_$lang_Code.ts
	cp ReverseEngineering.qm ~/$FreeCAD/src/Mod/ReverseEngineering/Gui/Resources/translations/ReverseEngineering_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for ReverseEngineering_$lang_Code_Upper_Case";;
    "Robot.ts")
	echo	"Robot.ts"
	lrelease  Robot.ts
	cp Robot.ts ~/$FreeCAD/src/Mod/Robot/Gui/Resources/translations/Robot_$lang_Code.ts
	cp Robot.qm ~/$FreeCAD/src/Mod/Robot/Gui/Resources/translations/Robot_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for Robot_$lang_Code_Upper_Case";;
    "Ship.ts")
	echo "Ship.ts"
	lrelease  Ship.ts
	cp Ship.ts Ship_$lang_Code.ts
	cp Ship.qm Ship_$lang_Code.qm
    "Sketcher.ts")
	echo " Sketcher.ts"
	lrelease  Sketcher.ts
	cp Sketcher.ts ~/$FreeCAD/src/Mod/Sketcher/Gui/Resources/translations/Sketcher_$lang_Code.ts
	cp Sketcher.qm ~/$FreeCAD/src/Mod/Sketcher/Gui/Resources/translations/Sketcher_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for Sketcher_$lang_Code_Upper_Case";;
    "Spreadsheet.ts")
	echo " Spreadsheet.ts"
	lrelease  Spreadsheet.ts
	cp Spreadsheet.ts ~/$FreeCAD/src/Mod/Spreadsheet/Gui/Resources/translations/Spreadsheet_$lang_Code.ts
	cp Spreadsheet.qm ~/$FreeCAD/src/Mod/Spreadsheet/Gui/Resources/translations/Spreadsheet_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for Spreadsheet_$lang_Code_Upper_Case";;
    "StartPage.ts")
	echo "StartPage.ts"
	lrelease  StartPage.ts
	cp StartPage.ts ~/$FreeCAD/src/Mod/Start/Gui/Resources/translations/StartPage_$lang_Code.ts
	cp StartPage.qm ~/$FreeCAD/src/Mod/Start/Gui/Resources/translations/StartPage_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for StartPage_$lang_Code_Upper_Case";;
    "TechDraw.ts")
	echo "TechDraw.ts"
	lrelease  TechDraw.ts
	cp TechDraw.ts ~/$FreeCAD/src/Mod/TechDraw/Gui/Resources/translations/TechDraw_$lang_Code.ts
	cp TechDraw.qm ~/$FreeCAD/src/Mod/TechDraw/Gui/Resources/translations/TechDraw_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for TechDraw_$lang_Code_Upper_Case";;
    "Test.ts")
	echo " Test.ts"
	lrelease  Test.ts
	cp Test.ts ~/$FreeCAD/src/Mod/Test/Gui/Resources/translations/Test_$lang_Code.ts
	cp Test.qm ~/$FreeCAD/src/Mod/Test/Gui/Resources/translations/Test_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for Test_$lang_Code_Upper_Case";;
    "Tux.ts")
	echo "Tux.ts"
	lrelease  Tux.ts
	cp Tux.ts ~/$FreeCAD/src/Mod/Tux/Resources/translations/Tux_$lang_Code.ts
	cp Tux.qm ~/$FreeCAD/src/Mod/Tux/Resources/translations/Tux_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for Tux_$lang_Code_Upper_Case";;
    "Web.ts")
	echo "Web.ts"
	lrelease  Web.ts
	cp Web.ts ~/$FreeCAD/src/Mod/Web/Gui/Resources/translations/Web_$lang_Code.ts
	cp Web.qm ~/$FreeCAD/src/Mod/Web/Gui/Resources/translations/Web_$lang_Code.qm
	echo "Finish. Now you may re-build FreeCAD to see updated translation for Web_$lang_Code_Upper_Case";;
    *) echo "Run script with one of .ts file as argument!";;
esac
kaktus
Post by kaktus »
Kuzma30
I'm not sure I understand your intentions.
Therefore, I will preempt the facts. :roll: FreeCAD does not need to be compiled every time for the changes in GUI translations to take effect. :idea:
Kuzma30
Post by Kuzma30 »
kaktus wrote: Sun Apr 17, 2022 1:01 pm Kuzma30
When I place new .ts in FreeCAD source tree and re-run build, I always see for example Building of qrc_Sketcher.cpp.o and linking SketcherGui.o and PartDesignGui.o (I work with Skether.ts now) May be if I store all .ts files in predefined directory it will work without recompile. Not testing yet)
kaktus
Post by kaktus »
It is worth to have a look there, I have completed the content ...
