App::Links in Part workbench
TheMarkster
Post by TheMarkster »
You will need a very recent build for this as it was only recently merged.
App::Link support in Part workbench has been fixed for many dialogs. This needs testing before the 0.20 release so if there are any major issues (such as crashes) these can be addressed now.
Also possible, in addition to using App::Links, is using App::Part containers in these functions.
The way the App::Part support works is the Part container must have a visible Part::Feature, which is used for the function. (While visibility matters for objects inside the App::Part, the App::Part's visibility is unimportant for functions that use it.) For example, put a Sketch into an App::Part and use the App::Part for extruding. Put another sketch into the same App::Part. Notice how the App::Part is treated as a compound. Make a sketch invisible and see the effect on the extrude. Using the Part itself as Base of the Extrude avoids links out of scope warnings if the Extrude is not in the Part container. (Expect self-intersection errors quite often where these sketches intersect. This can be remedied by using Part::Union on the Extrude object.)
Edit: I should have added: only the visibility of top level objects will matter for the purposes of the App::Part's compound shape.
Re: App::Links in Part workbench
TheMarkster wrote: Mon Apr 11, 2022 4:13 am You will need a very recent build for this as it was only recently merged.
Can you give a revision number?
Zolko
Post by Zolko »
This looks like now, one can use links to a sketch as base for functions (like Extrusion) in the Part workbench with Part containers. I tested and it seems to work. This is really great news, thank-you very much. This should definitively be incorporated into v0.20
Next step would be to place the resulting function into the Part where the sketch or the link to the sketch is: if I create a Part and in that part I create a sketch, and then I extrude the sketch, the solid "Extrude" is outside the Part with the following strange warning message:
Part::Extrusion: Link(s) to object(s) 'Sketch_1' go out of the allowed scope 'Extrude'. Instead, the linked object(s) reside within 'Part'.
OS: Debian GNU/Linux 10 (buster) (KDE//usr/share/xsessions/plasma)
Version: 0.20.28633 (Git)
Build type: Unknown
Hash: 35913fc695a504bc287c34cddd622835e369a205
Python 3.7.3, Qt 5.11.3, Coin 4.0.0a, OCC 7.3.0
  * A2plus
  * CurvedShapes 1.0.1
  * fcgear 1.0.0
  * sheetmetal 0.2.49
  * TabBar
  * Render 2022.1.0
  * fasteners 0.3.40
  * Curves 0.4.1
  * WeldingWB_GitHub 0.0.1
  * Assembly4_GitHub 0.11.10
chrisb wrote: Mon Apr 11, 2022 7:05 am Can you give a revision number?
git commit 731ed820b5ec24a. Revision number must be 28659.
openBrain
Post by openBrain »
wmayer wrote: Mon Apr 11, 2022 12:22 pm git commit 731ed820b5ec24a. Revision number must be 28659.
28660 ;)
TheMarkster
Zolko wrote: Mon Apr 11, 2022 11:04 am
That seems sensible, to put new objects into the active App::Part, if there is one. I have noticed when creating a new primitive it does go into the active App::Part, so evidently some work has been done in this direction already. Cyclic dependencies must be checked for, and if there is an active PartDesign::Body, then any new PartDesign::Feature should go into it instead of the App::Part, including Sketches.
