[New feature] Sketcher Constrain Contextually
paddle
Post by paddle »
Note the video is out of date with what actually merged.
phpBB [video]
A tool that create constraints depending on what you click!
Github branch if you want to test : https://github.com/PaddleStroke/FreeCAD ... Contextual
Feature discussion : https://forum.freecadweb.org/viewtopic.php?f=19&t=64648
Pauvres_honteux wrote: Mon Dec 20, 2021 9:25 pm issue #1416 Constraints creation "on the fly"
Surprise!
adrianinsaval wrote: Mon Dec 20, 2021 5:59 pm This would be a welcomed addition by most people I think, also consider making the m key switch between the different constraints available for the selection.
Yes a key to change between available constraints is the next step. Though it's already pretty cool now. :D
Haavard
Re: NEW FEATURE ! Sketcher Constrain Contextually
Post by Haavard »
WOW, great job! Been dreaming about a feature like this since i started using freecad years ago :D
This looks like a really poweful tool which should speed up constraining quite a lot. Will give it a test this weekend and give more feedback.
Small suggestion for now:
1: Could the auto diameter/radius tool be used instead of diameter as default? So that if you select a circle you get diameter, and radius for an arc?
2: Other software will automatically switch between horizontal length, vertical length or distance, based on mouse position:
length tool.png (17.94 KiB) Viewed 43901 times
- Say you click on line A, you will only get vertical length as an option, or horizontal for B.
- If you click C, the position of the mouse in relation to the "projection" of the line will determine if distance or horizontal/vertical length should be applied.
I have no idea if this is hard to implement, perhaps just checking if the line is already axially constrained, and if so switch from distance to horizontal/vertical is good enough?
Great! I'll try to take a better look later
bleber
Post by bleber »
How about more dinàmic construction with poliline, it is extensively used for speed modelling profiles.
i like to see enter dinamically constraints when enter diferent segments and change type segment with m key.
Thanks.
paddle
Post by paddle »
Haavard wrote: Thu Jan 20, 2022 11:34 pm WOW, great job! Been dreaming about a feature like this since i started using freecad years ago :D
1 - I think that depends a lot on user preferences. Myself I prefer to always use radius as it's more consistent to use always the same. Using both diameter and radius requires more brain-power to not make mistake IMO.
2- This is a really great idea! I'm totally going to make it.
bleber wrote: Fri Jan 21, 2022 1:36 am How about more dinàmic construction with poliline, it is extensively used for speed modelling profiles.
Thanks.
Are you talking about that ? https://forum.freecadweb.org/viewtopic.php?f=9&t=65279
paddle
Post by paddle »
Haavard wrote: Thu Jan 20, 2022 11:34 pm 2: Other software will automatically switch between horizontal length, vertical length or distance, based on mouse position:
That's it it's working and it's awesome! Thanks for the idea!
phpBB [video]
bambuko
Post by bambuko »
paddle wrote: Fri Jan 21, 2022 8:20 am ...Myself I prefer to always use radius as it's more consistent to use always the same. Using both diameter and radius requires more brain-power to not make mistake IMO...
Like the whole idea very much apart from radius ve diameter business.
I have reasons to use one or the other as necessary and if anything using radius on the feature that requires me to know the diameter require more brain power ;)
You might prefer radius, but there is a whole bunch of us who prefer to make this decision ourselves, please :ugeek:
paddle
Post by paddle »
bambuko wrote: Fri Jan 21, 2022 9:36 am
I don't specifically prefer one or the other. I prefer that it stays the same.
Though one possibility is to have a key which alternate between the available constraint.
So you select a circle/arc, then it creates the radius constraint. Click on 'Shift' key. Then it changes to diameter.
Would that be what you're looking for?
bambuko
Post by bambuko »
paddle wrote: Fri Jan 21, 2022 9:54 am ... I prefer that it stays the same...
I know you do :)
and I know CAD doesn't care (as long as it is constrained), but I (as a designer) do care whether it is one or the other.
paddle wrote: Fri Jan 21, 2022 9:54 am ...Though one possibility is to have a key which alternate between the available constraint...
I am normally a "mouse man" so would prefer context mouse click to allow choice, but keyboard key is usable as well
paddle wrote: Fri Jan 21, 2022 9:54 am ....So you select a circle/arc, then it creates the radius constraint. Click on 'Shift' key. Then it changes to diameter.
Yes, I would be looking for a choice at this point,
if "Shift" key is the way, then I am sure I could get used to it, although as mentioned above would prefer to use a mouse (or "shift" key for those who prefer keyboard - I know a lot of Linux guys like keyboard shortcuts ;) )
Haavard
Post by Haavard »
paddle wrote: Fri Jan 21, 2022 9:34 am
Absolutely brilliant!!! I'm in awe :shock: Been thinking about this feature for years, but have not had time to learn c++ and attempt it myself yet.
Hopefully someone can clone this feature in techdraw, that would make dimensioning drawings a blast :D
Getting off work soon, will try to compile and test.
