Addon Manager Redesign 2021
Re: Addon Manager Redesign 2021
I think the issue will probably be resolved by git commit 46b70c73fe -- if you are able to check that, please report back.
What is the correct way of refreshing Addon Manager cache (on Linux)
As example, I'm trying to iinstall toSketch WB.
In image1 you will see the starting situation, no toSketch on the list
Image1 in IMage2 you will see the situation after having pressed the "refresh local cache" button.
toSketch is existing but not informations nor icon is shown.
in image3 the situation after having installed the WB but prior to restart FC.
Image3 After having restarted FC sadly it return to image1, and even in the "installed package" toSketch is not shown if I don't "refresh local cache"
So it seems that local cache is not cached at all? or maybe it is using some hardcoded path other than deriving from user_dir that I have as "per session" issuing:
prior to start FC Appimage, tested and screenshot from:
But even for 0.21 with conda-install is the same.
It seems that cache is not modified by AddonManager or I have to set something in Preferences?
export FREECAD_USER_HOME="/home/common/FreeCAD/config-020-eng"
OS: Artix Linux (openbox)
Locale: Italian/Italy (it_IT)
* Curves 0.5.7
- adrianinsaval
something weird going on with that addon, it doesn't show in the webpage of the addons repo: https://github.com/FreeCAD/FreeCAD-addons but it is listed in .gitmodules files
It seems that the page you linked is not up to date, as it is very old as example if you see Curves Wb it is left at 0.4.2 version (now it is at 0.5.7, or at least this is the version I have).adrianinsaval wrote: ↑Tue Sep 06, 2022 1:26 pm something weird going on with that addon, it doesn't show in the webpage of the addons repo: https://github.com/FreeCAD/FreeCAD-addons but it is listed in .gitmodules files
The link on this github page point at:
https://github.com/tomate44/CurvesWB/bl ... ackage.xml
But this is the actual version of Curves WB.
So probably another question is what is the correct way to add an "Add-On" as example a WB to the AddOnManager?
Other than complying with this passage:
Submit a Pull Request to this repository adding your Addon to the .gitmodules file. Supported git hosts are GitHub, Gitlab, Framagit. ...
The strange behaviour is present even in 0.21.30xxx now I've not fired up FC but it is a week old "conda install".
Any hint?
PS: Amended post to delete some not relevant images.
- adrianinsaval
That's normal, the submodules are used just to give the addon manager a link to the repo, in normal git usage these are supposed to point to a specific commit and that's why when you follow the link it shows an old version (this is the version when the submodule was added). The addon manager of course knows better and checks out the latest available.
But the case with toSketch is weird because it's not even shown, perhaps the module was not initialized? I'm not sure what is needed to get it displayed. I would guess the addon manager should still function though.
my guess is that not all addons in the repo have a package.xml file and only those who have them would be in that directory, this is just a guess so I might be completely wrong.
I amended the page, as at a second check probably the content is split from WB and Macros.adrianinsaval wrote: ↑Tue Sep 06, 2022 2:22 pmmy guess is that not all addons in the repo have a package.xml file and only those who have them would be in that directory, this is just a guess so I might be completely wrong.
From what I could guess from the page the only requirements a part from those in the wiki are to add the module to the .gitmodules file.
And I suspect that is linked to the way AddOnManager manage the cache, as I've seen that after a FC restart even installed modules are not shown until I do a "refresh local cache"
- something is happening to the cache, or it is not loaded from "the right place", as I'm assigning a different "user directory" for FC for every version I've installed as told above in an another post.
- or there cache is not overwritten after installing a wb, so it is not found. (but FC is knowing that is installed as it is "regularly" put in the Mod dir)
Thanks again.
The branch name is wrong in the package.xml file -- it lists "master", but the actual branch is "main". This causes all sorts of havoc in the AM, which is at first able to fetch a package.xml file, but cannot then use the information in it.
Thanks I will amend the information.
EDIT2: erratic behaviour, now it is not working anymore, I can install the addon, and I've amended the package.xml as follow:
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<package format="1" xmlns="https://wiki.freecad.org/Package_Metadata">
<name>toSketch</name>
<description>Add toSketch facility for FreeCAD. This WB help with remodelling of existing models.</description>
<version>1.0.0</version>
<maintainer email="keith@sloan-home.co.uk">Keith Sloan</maintainer>
<license file="LICENSE">GPL-2.0</license>
<url type="repository" branch="main">https://github.com/KeithSloan/toSketch</url>
<url type="readme">https://github.com/KeithSloan/toSketch/README.md</url>
<content>
<workbench>
<classname>toSketch_Workbench</classname>
<subdirectory>./</subdirectory>
<icon>freecad/toSketch/Resources/icons/toSketch.svg</icon>
<freecadmin>0.19.0</freecadmin>
<tag>sketcher</tag>
</workbench>
</content>
</package>
I've noted that it will insist to point me when i select toSketch and press the mouse to the README.md with the following url:
https://github.com/KeithSloan/toSketch ... README.md
despite changes in the above file
I have deleted the /home/common/FreeCAD/config-020-eng/temp/AddonManager/r directory but nothing has changed.
These informations are stored elsewere?
After having deleted the cahe directory I have this file /home/common/FreeCAD/config-020-eng/temp/AddonManager/package_cache.json that contain this "stanza" where the branch is "master".
"toSketch": {
"name": "toSketch",
"display_name": "toSketch",
"url": "https://github.com/KeithSloan/toSketch",
"branch": "master",
"repo_type": 1,
"description": null,
"cached_icon_filename": "",
"python2": false,
"obsolete": false,
"rejected": false,
"requires": [],
"blocks": [],
"python_requires": [],
"python_optional": []
- adrianinsaval
The package.xml must be fixed in the add-on repo I believe
I think @keithsloan52 is the author? If there's no response please open an issue or make a PR to the add-on repo
I'm "working" for keithsloan to fix up his repositories
