Addon Manager Redesign 2021
Re: Addon Manager Redesign 2021
@chennes : The same problem
- Capture d’écran 2022-07-27 190435.jpg (116.88 KiB) Viewed 1909 times
- Capture d’écran 2022-07-27 190504.jpg (26.44 KiB) Viewed 1909 times
- Capture d’écran 2022-07-27 190523.jpg (45.73 KiB) Viewed 1909 times
My installed workbenches don't appear neither in the global list.
- Capture d’écran 2022-07-27 190839.jpg (77.47 KiB) Viewed 1903 times
But everything is OK now after suppressing Freecad.gears wb.
(I have reinstalled it and no more problem.)
Weird problem.
Thank you for your time.
Weird problem.
Thanks for investigating -- freecad.gears has had some issues recently, I'm not sure what's going on. Last I checked it still didn't have a matching branch name, and its commit history seemed to have gotten edited.
I don't know if it is THIS wb (but it was my last used wb).
From users' perspective I hope this latest change is basically invisible: but I've just removed the requirement for GitPython from the AM, so now all you need is git itself. I've also made it easier to disable the use of git, by adding a UI element in the preference to turn it off. I hope that this change provides greater stability to updates: the code should now provide fewer errors to end users, and just push through any git-related problems. I tested it on the systems I have access to, but of course I am looking forward to your comments if things don't work as expected .
Hi
i have this errors and only 1 macro
11:17:18 Traceback (most recent call last):
11:17:18 File "C:\FreeCAD_weekly-builds-30143-2022-08-21-conda-Windows-x86_64-py310\Mod\AddonManager\addonmanager_workers_startup.py", line 100, in run
11:17:18 self._retrieve_macros_from_git()
11:17:18 File "C:\FreeCAD_weekly-builds-30143-2022-08-21-conda-Windows-x86_64-py310\Mod\AddonManager\addonmanager_workers_startup.py", line 276, in _retrieve_macros_from_git
11:17:18 self.status_message_signal.emit(message)
11:17:18 AttributeError: 'CreateAddonListWorker' object has no attribute 'status_message_signal'
11:19:03 Traceback (most recent call last):
11:19:03 File "C:\FreeCAD_weekly-builds-30143-2022-08-21-conda-Windows-x86_64-py310\Mod\AddonManager\addonmanager_workers_startup.py", line 100, in run
11:19:03 self._retrieve_macros_from_git()
11:19:03 File "C:\FreeCAD_weekly-builds-30143-2022-08-21-conda-Windows-x86_64-py310\Mod\AddonManager\addonmanager_workers_startup.py", line 276, in _retrieve_macros_from_git
11:19:03 self.status_message_signal.emit(message)
11:19:03 AttributeError: 'CreateAddonListWorker' object has no attribute 'status_message_signal'
mario
Version: 0.21.30143 (Git)
Hash: a72bf218f9917df37e811d7e73a36333282028f5
Python 3.8.13, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
That build is from before the commit series that added this feature -- which also fixes that bug . So you'll have to wait for the next build if you want to use Conda.
Hi
merci
mario
merci
mario
Just installed the new conda installa, and I have this error:
Addon Developer Warning: Repository branch set in package.xml file for addon freecad.gears workbench (develop) does not match the branch it was fetched from (master)
File "/home/carlo-arch/miniconda3/envs/fcenv-dev/Mod/AddonManager/addonmanager_workers_startup.py", line 100, in run
File "/home/carlo-arch/miniconda3/envs/fcenv-dev/Mod/AddonManager/addonmanager_workers_startup.py", line 276, in _retrieve_macros_from_git
OS: Artix Linux (openbox)
Locale: Italian/Italy (it_IT)
* test_wb
* fcgear 1.0.0
* Curves 0.4.1
* Help 1.0.3
conda install is a fresh install done with:
mamba create --name fcenv-dev --channel freecad/label/dev freecad
