Addon Manager Redesign 2021
- adrianinsaval
Re: Addon Manager Redesign 2021
I concentrate on Linux because this has only changed on Linux there was change in macOS too if I'm not mistaken, in order to follow Apple's standard for these files, and on windows they are placed under %APPDATA%/FreeCAD in order to follow window's standard (although IMO this isn't fully respected either since some stuff is probably supposed to go to appdata/local/FreeCAD). You are right that FreeCAD is multiplatform and as such it adapts to the OS using Qt's functions to find these folders.
Don't like it? Use the option to use deprecated paths or set the XDG env variables you want to have your data wherever you want. You know the best thing about this being standard? You can use those env variables for a lot of other apps.
Indeed, they are now in ~/Library/Application Support/FreeCAD/Mod instead of ~/Library/Preferences/FreeCAD.adrianinsaval wrote: ↑Sun Jul 03, 2022 3:14 pm there was change in macOS too if I'm not mistaken, in order to follow Apple's standard for these files
Honestly if you don't like the fredesktop stuff, I have linked my .FreeCAD to .local/share/FreeCAD and the problem is solved, works just like 0.19, never had to look at it again.
Regarding the addon manager, yes, using another file (with more "fields" than the .gitmodules file) seems interesting, but: 1) it's harder to maintain, the .gitmodules is automaticly handled by git, 2) is it not possible to add fields manually to the .gitmdules? Maybe they are not overwritten... In any case it's possible to add a branch info: https://www.git-scm.com/docs/gitmodules and 3) then we might also want to allow not only the developer to specify a branch, but the user to "pin" a specific branch too (like in zolko's case)
Maybe what could be interesting:
- the .gitmodules can optionally feature a default branch for a given addon
- the addonmanager scans for available branches and gives users a drop-down menu of available branches (with the default one recommended)
- the addon manager remembers the installed branch
Sorry I had not followed this thread, just in a discussion with an user it comes to my attention that there is no longer 'Configure' in the dialog box.
Any idea there is still a way to do 'configure' similar to earlier design? To add a repository which is not yet included in the list.
Thanks for any idea
[ EDIT - Just google search to find this thread, and just realise this is in the Announcement sub-forum, any better place to discuss its develpement other than here? Thanks. ]
Thanks for any idea
But we don't actually use that functionality, except to allow GitHub to provide links for us -- which it does incorrectly, since technically a git submodule is locked to a particular revision. So we are only kind of using .gitmodules, and we use it wrong .
This is already done -- we assume "master" if nothing is provided, but the developer can give us whatever branch they want to.- the .gitmodules can optionally feature a default branch for a given addon
This already exists, if you enable the advanced options and have GitPython and git installed -- but doesn't allow any flexibility to the developer to provide a specific list of branches they want to display, it just shows all of them, and has no way of knowing if one or more of them are incompatible with the current version of FreeCAD.- the addonmanager scans for available branches and gives users a drop-down menu of available branches (with the default one recommended)
It does this.- the addon manager remembers the installed branch
Those preferences were moved to the main FreeCAD preferences dialog.
Thanks @chennes
okay mytarguments have basically all melted i'm convinced!
Sorry if the answer is above.
If [Status=Installed] and [Show=Workbenches], I don't see the workbenches shown with [Show=All].
Is it normal ?
(btw, this Addon Manager redesigned is fantastic)
Is it normal ?
Version: 0.21.29485 (Git) -- 2022/07/10
Hash: a236ca843fdd6674afb6d7ed1454fbd3b547f5ea
Locale: French/France (fr_FR)
* fasteners 0.3.50
* fcgear 1.0.0
* Manipulator 1.4.9
* sheetmetal 0.2.52
- Capture d’écran 2022-07-26 130941.jpg (51.51 KiB) Viewed 1545 times
- Capture d’écran 2022-07-26 130953.jpg (23.84 KiB) Viewed 1545 times
No, it's not: actually, the display you are seeing there doesn't have the correct icons or other metadata for those workbenches either. I can't reproduce here. If you switch to expanded view does it show anything different?
