Addon Manager Redesign 2021
- adrianinsaval
Re: Addon Manager Redesign 2021
can't you trick it into believing there are updates necessary by checking out an older commit of the repo?
No, then you're in detached head, git knows you did it deliberately.
When trying to install GDML workbench i see this in the Report view:
looks like there's a missing double quote somewhere
11:00:30 b'pip 22.0.4 from /snap/freecad-ppd/223/lib/python3.8/site-packages/pip (python 3.8)\n'Nonepip 22.0.4 from /snap/freecad-ppd/223/lib/python3.8/site-packages/pip (python 3.8)
In addition to the above, I noticed an UX issue with the Addon Manager when installing 3rd party deps the dialog directs the user to browse the Report view console but that is out of focus when we're in the Addon Manager. Is there a way to clone/mirror the report view to the bottom of the Addon Manager window for the duration of the Addon Manager being active and in focus? Upon exiting the Addon Manager the Report view is 'returned'? This way we can watch the activity of the addon manager, copy/paste text from the report view (without having to exit Addon Manager to do so)
That's an artifact of the way pip echos its output, I don't think I have any control over that.
Fascinating, so you can you recreate that in pip directly?
While performing to update my addons using recent master I got this error:
14:44:21 Syntax error while reading __files__ from macro AeroFoil
14:44:21 __Files__ = "AeroFoil_UI_Files/AeroFoil_Initial_Dialog.ui, AeroFoil_UI_Files/AeroFoil_NACA4Digit_Dialog.ui, \
It looks like the problem is in the script that's on the Wiki -- the one in GitHub is fine. https://wiki.freecadweb.org/index.php?t ... o_AeroFoil uses the Python line continuation character in its list of __Files__, which is not allowed. Those metadata lines are not actually executed by the Addon Manager, they are just hand-parsed. I modified that code a little bit in this redesign to allow for certain common idioms, but actually moving to executing the Python I think is beyond the scope of something the Addon Manager should do.
In the update report can the new versions be displayed? Is it possible an update can be applied from cache and not be the very latest?
