OK that actually does not do the trick. The matrix is derived from the parent object so it only works for planar Draft objects.
Draft Hatch
Re: Draft Hatch
I think I have found a solution for the relocation bug. In this version of hatch.py the first edge and the normal of the face are used to create a matrix. This offers a level of control over how the shape is translated to the XY plane. The first point of the first edge is put on the origin, the first edge will be aligned with the X-axis.
If you create wires with that in mind you can control how the hatch is aligned with the outline. For wires on the XY plane the Translate property can then be used to switch between relative and absolute patterns.
Also included in the ZIP file are two test files and the PAT file I have used.
- hatch.zip
- (51.63 KiB) Downloaded 78 times
- insul-zigzag.png (11.45 KiB) Viewed 4896 times
Re: Draft Hatch
Merged.
- ragohix769
Re: Draft Hatch
- wepz.png (262.64 KiB) Viewed 4498 times
Re: Draft Hatch
Merged.
