CheckGeometry tool now with advanced shape content
TheMarkster
Post by TheMarkster »
CheckGeometry tool in Part workbench now includes advanced information in the Shape Content panel. This includes information such as volume, mass, length, area, center of mass, among other things, depending on the type of shape object being checked. This screenshot is from checking a default Part workbench Cube object:
Snip macro screenshot-857f7f.png (27.79 KiB) Viewed 3568 times
I don't know what some of that stuff means, but I'm sure someone does.
Advanced shape content can be disabled in the settings:
Snip macro screenshot-2ae005.png (27.08 KiB) Viewed 3568 times
This is when checking a sketch containing a single arc of circle, end points constrained to the horizontal axis 180 degrees apart, centered at the origin with radius 5mm:
Snip macro screenshot-920c07.png (28.56 KiB) Viewed 3568 times
And this the same sketch, but now it's a full circle instead of the semi-circle:
Snip macro screenshot-8a8ad3.png (27.77 KiB) Viewed 3568 times
Notice how the isClosed property is true for one and false for the other. And also the center of mass is different for the arc since all of the mass of the object is above the x axis.
sgrogan
Re: CheckGeometry tool now with advanced shape content
Post by sgrogan »
TheMarkster wrote: Fri Sep 11, 2020 9:48 pmmass,
Where is density pulled from? Looks like 1 by default.
"fight the good fight"
TheMarkster
It's done with python and produces whichever value gets returned from:
obj.Shape.Mass
where obj is the object being checked.
sgrogan
Post by sgrogan »
TheMarkster wrote: Fri Sep 11, 2020 10:11 pm It's done with python and produces whichever value gets returned from:
Thanks, but I still don't understand.
For example a default Part Cube.
Do I need to use an Arch or FEM object that supports material, or add a property with dd Workbench to the cube?
I think I'm missing something very fundamental.
vocx
Post by vocx »
sgrogan wrote: Fri Sep 11, 2020 10:07 pm Where is density pulled from? Looks like 1 by default.
I think it just uses the default units.
For example, a cube of 1 mm x 1 mm x 1 mm (unit length in each direction), that is, 1 mm^3, corresponds to one 1 unit volume, and has a mass of 1 unit mass, which is 1 kg. So the basic density would be 1 kg/mm^3.
>>> App.Units.Mass
Unit: kg (0,1,0,0,0,0,0,0) [Mass]
>>> App.Units.Volume
Unit: mm^3 (3,0,0,0,0,0,0,0) [Volume]
>>> App.Units.Density
Unit: kg/mm^3 (-3,1,0,0,0,0,0,0) [Density]
You could define another parameter to hold a custom density and calculate the mass in that way.
TheMarkster
At this time CheckGeometry does not calculate any of that information. It only reports what's already there, which can be found by examining the object in the python console. For example, the mass is reported as what can be found by entering obj.Shape.Mass in the python console. The same is true for the other properties reported, such as Area, Volume, Length, etc. if somebody knows a way in python to check for the material associated with an object to get its density I can add some code to CheckGeometry to find a calculated mass and report that.
Vincent B
Post by Vincent B »
nice improvement. easy to use. ;)
Nice this needs to be added to the 0.19 release notes
Along with Macro Recent history list
Great work TheMarkster!
jmaustpc
Post by jmaustpc »
TheMarkster wrote: Fri Sep 11, 2020 9:48 pm This is when checking a sketch containing a single arc of circle, end points constrained to the horizontal axis 180
Seems strange that 2d objects have a mass. On my phone just now, so no idea if that is being wrongly reported in checkgeometry or if it's there in the object itself.
polymer
Post by polymer »
What about projected surface area in X, Y and Z direction?
