Manipulator WorkBench
Re: Manipulator WorkBench
Thanks for immediate responses.
Sorry for a FreeCAD and Python newbie issue. I was confused from the Python console output, where .getObject("...") is printed, using an objet label. This does not work from Python code, .getObjectsByLabel("...")[0] must be used instead. Finally I found Code snippets in the FC wiki and realized, how to access objects.
Probably I should try the pre 0.19, if this is fixed in it.
OS: Windows 10
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: Czech/CzechRepublic (cs_CZ)
OS: Windows 10
Qt version: 5.6.2
In FreeCAD there are two way to get an Object, by Name or by Label
Name is unique and is created when an objects is created, but the name must be unique and some magics are done when creating a Name, spaces, and some other characters are translated to underscores, so even when creating using a script it is not ever true that your name string is the real object.Name.
If there are another name equal the .Name is added by 0001, 0002, and so on.
Label is not unique, (they could be made unique setting an options somewhere, but at moment I don't remeber where), so a list is returned even if there are only one object that match the query .getObjectbyLabel()
0.19 will be stable in some days, (feature freeze and bug hunting is under active work at this moment)
Hope that this could help.
this discussion is deviating toward a python one more than related to Manipulator.. would a moderator split it please?
Where do i split from? and what should the new topic be called?
Could be useful to see the plane name on the RefPlaneplane.
... on any datum plane as well.
- Capture.JPG (17.72 KiB) Viewed 4698 times
Oh my...you just visually described everything I've ever dreamed of for a datum plane...is that a mockup or a true current function?
just a ShapeString on the plane.
I'm more mesmerized by the Coordinate system although the shapestring really brings the bread home!
https://forum.freecadweb.org/viewtopic. ... on#p469998
I have a part-container with two bodies inside. Is there any way to move one body only using Manipulator?
Watching the "Manipulator-WB-Mover-with-App_Part&Body.gif" seems possible .
